catastrofic caddy lifter failure...
Old Mar 6, 2008 | 08:04 PM
fossil's Avatar
Sorry to hear your problem... I had the same thing happen with stock lifters 2 years ago. So everyone knows stock gm lifters application are as follows 4.8, 5.3, 6.0, and yes 7.0 LS7, same part number.... Found after research that I had to much preload.. I now run less than half of recommended preload with no concerns of valvetrain unstability. Just a little noisey on intial startup for a few seconds, but will rev to 7,000 rpms very quick. Goodluck
Old Mar 6, 2008 | 08:11 PM
Daryn's Avatar
Formerly darynC-10/23/10
rule of thumb... " you get what you pay for" spend the money and get morels or go mechanical
Old Mar 6, 2008 | 08:12 PM
DaveX's Avatar
What are your cam specs and what springs are you running?
Old Mar 6, 2008 | 08:17 PM
Dave 96TA's Avatar
sucks dude
Old Mar 6, 2008 | 09:11 PM
ls2 bait's Avatar
these had 2k miles on them. got them about 6-7 months ago. i actually waited for them to come off backorder and held up my build for them. tfs 215's milled to 60cc, tsp torquer 2 cam, ported ls6 oil pump. had great pressure up until they let go. then i lost it. running the patriot extreme gold springs and they all seem to be perfect. i rev it to 6800 when im in it. it just got noisier over the last 500 miles or so. i chalked some of it up to the fats manifold being a thinner plastis etc but i guess that wasnt the case. im wondering if i just got a bum batch as there are several people running them with success.
Old Mar 6, 2008 | 09:15 PM
ls2 bait's Avatar
Originally Posted by heavymetals
thats the same place one of mine cracked but my crack is a lot larger. 2 of them did that. one lost the roller completely.
Old Mar 6, 2008 | 09:55 PM
heavymetals's Avatar
Guess you got to beat the crap out of yours a little bit more......
Old Mar 6, 2008 | 09:59 PM
I think what adds to the problem is that some of the high lift cams reduce the base diameter so the lifter can drop further past the edge of the bore.
Old Mar 6, 2008 | 10:59 PM
98mysticZ's Avatar
i had a set of these like that before i put them in.. was looking in the box and noticed that it was cracked just like that looked like it was dropped before shipping and i also noticed alot of the other lifters 4-5 of them really nicked up.. called sdpc and sent them back waiting on my new set now.. makes me worried about buying them might just put my stockers back in..
Old Mar 7, 2008 | 12:42 AM
Xtnct00WS6's Avatar
yikes...I have the caddy lifters too. I'm not sure how many miles I have on them, but it's close to 2k. Hmm....
Old Mar 7, 2008 | 09:22 AM
ls2 bait's Avatar
its very possible mine were too and i just didnt look at them close enough. kinda gave em a quick look and soaked them in oil.
Old Mar 7, 2008 | 09:58 AM
  #32
Deeavi's Avatar
Amen to that "you get what you pay for"! The older I get the more I figure that is the truth. Spend the money now, so you won't have to spend alot more later!
Old Mar 7, 2008 | 11:23 AM
  #33
98mysticZ's Avatar
i was told by sdpc that they come in like a big set then they get reboxed and sent out.. so there is a poss sounds like a shipping issue and a handling issue when i returned the shippment on my return slip i stated that i wanted them wrapped carefully and then boxed.. and shipped so i will see how they are when i get them back...
Old Mar 7, 2008 | 11:30 AM
  #34
bjamick's Avatar
Ill just stick to a GM piece, thats why im going with the LS7 lifters in my build.. I hate to hear this happened to ya .. Hopefully the lifter bores are still in good shape.
Old Mar 7, 2008 | 11:38 AM
  #35
LSGunZ28's Avatar
what do they mean improper installation?
Old Mar 7, 2008 | 12:17 PM
  #36
slt200mph's Avatar
...what he said.. howudodat ..
Old Mar 7, 2008 | 01:46 PM
  #37
02TransAm/Batmobile's Avatar
So GM Caddy > LS7 > Morels now?
Old Mar 7, 2008 | 03:36 PM
  #38
99ssleeper's Avatar
I dont think one person having trouble with the Caddy lifters qualifies them as garbage.
Old Mar 7, 2008 | 04:22 PM
  #39
DaveX's Avatar
I think mine are the LS7 lifters but they looked like the original LS1 lifters they replaced. I don't know what the difference is in the LS7 & caddy lifters but I hope these hold up better. Got me thinking now tho. Good luck with your rebuild.
Old Mar 7, 2008 | 05:24 PM
  #40
99ssleeper's Avatar
LS2 Bait, what valvesprings/retainers were you using? What kind of valves and what size?
