catastrofic caddy lifter failure...
If after 2k miles my caddy lifters take a dump on me, this board will be the first hear all about it.
NEW GM Performance Parts Hydraulic Roller Lifter for LS-Engines
#SD8689 $217.85/set
You heard it first from SDPC! This new lifter will work in all LS- engine applications and is specifically suited for race cams and high RPM applications. They can also be used as an upgrade for stock lifters and are suitable for street applications. These lifters were developed for the CTSV Cadillac Race Team that used the “short stroke” LS7 style engines that raced in the Grand Am Cup Series during 2005. If you recall these engines were built using the LS7 block, LS7heads, and LS7 intake but the sanctioning body required the teams to meet the 5.7-liter engine size of 346ci. There were several different combinations tried but most of these engines used a stroke of approximately 3.200”. The demand to make race winning horsepower with a short stroke guarantees the unavoidable element of high RPM’s.
Initial testing, before these new lifters were developed, showed a definite valvetrain stability problem above 7000-rpm’s. Several remedies were tried, but in the end it was determined that the lifter had the biggest contribution to the RPM limit. This new lifter has internal changes made to the hydraulic components which resulted in a significant RPM increase. After installing the new lifters, these engines were now making power at 8000-rpm and they regularly saw 8500-rpm’s without any problems! WOW! The CTSV dominated the first races, not only did the sanctioning body enforce an RPM limit on the short stoke Caddies but they eventually implemented more restrictions to limit the horsepower on these LS7 equipped 346ci engines.
As a reminder, hydraulic roller cam valvetrain stability is a function of many different variables; camshaft design (ramp acceleration), pushrods, valve springs, rocker ratios, spring pressures, valve weight, the weight of all valvetrain components, oil pressure, RPM, etc. It is imperative that you have sufficient spring pressures, quality push rods and lifters, proper lash adjustment, and the lightest valvetrain components you can afford to maintain accurate stability at high RPM’s. Match your components to meet your RPM range!
We recommend a preload setting of 0.060” (cold) with these lifters, in most cases with adjustable rockers this is usually somewhere between 1-full turn and 1-1/2 from the “Zero-Lash” point. This is the same preload as a stock lifter!
I need to dig up the respective Morel and Crane part numbers to help me decide if I stay with the Caddy or switch.
Has anybody given some thougts about the relation between pushrod lenght ans Caddy lifter failure?
Off course, the Caddy's did not have any problems at Daytona; but, then again, the engine builders for those cars do measure pushrod lenght requirements. If you go ahead and replace the OEM's with some Caddy's just because you heard they are better without checking pushrod lengths for your particular application...
I just wonder... any related experience with different lenght pushrods? I hear some people saying that as a rule of thumb caddy lifters need at least 0.050" shorter pushrods than OEM's. In my case I am going to meassure with a pushrod length checker for pushrod lenght.
Anyway I looked @ the morels and the Crane's. Not sure where they're @ now but the cranes were the most expensive @ that time. I ended up goin with Lunati cuz @ that time all the information @ that time led to the Morels and the Lunati's being the same lifter. Had mine to 7k many times with no probs. yet "knocks on wood". Little over 1500 miles on the motor thus far. The LS7 and Caddy lifter were a new thing then and just wanted to wait and see how they performed.
