WTF is going on with my oil pressure?!
any advice?
thanks
That's some high stakes poker there...lol
I'm sure you guys know a lot more about it than I, and if the sending unit works...go for it man. Save some bucks.
Just be careful, untold damage to your rotating assembly, etc, etc can happen.
Im not saying go drag race the ******* thing. Sounds to me like he will know as soon as the sender is installed if it was the problem. I guess I needed to draw a picture that said "shut down if you lose significant oil psi".
Now make sure when you installed the oil pump you don't pinch that o-ring while installing the oil pump and do check your oil filter. The oil filter will tell you most of the story of your internals.
alrite, i already got new oil and filter to change it all out this weekend... ill get back to you
Pics of the damage .. kinda cool
www.fquick.com/CamaroZStyle28
-Joel
