looking for 450Rhp from heads and cam
I do agree with track times with an auto, ther is no granny shifting or 2.0 60 ft,s with an auto so they should run well into the 10's but the car has to be set up for the track as well and a slipping trans is not well set up for the track, Ive been doing alot of research into heads and cam packages and seen alot of legit 430's 440's and low 450's. it can be done, It figures the guy that claims its bs sells heads that only average 20 hp gains. just becuase he cant do it doesnt mean it cant be done
Now the setup has been on your car for a LONG while but u still havent made ANY hard runs in the car other than a 11.40@119?
I just dont undestand it?
I mean u have access to boots/skinnies and lets face it,your car weighs 3340lbs on STOCK WHEELS.If u add skinnies/slicks along with a few other lightening mods your car would be 3200lbs,U BETTER RUN 10's at that point and with that power over 124MPH...
Honestly I BELIEVE u are making the numbers.So dont get upset,everythings kewl.....
I'm not starting any crap other than to say u can run the car hard at ATCO for 2 runs before being thrown out.Just show up on boots/skinnies and make a hard run,you'll get the warning and then make one more pass and u know what will happen after that bro.
For god sakes u and I had it happen to us back 2yrs ago.So no excuses about not being able to make hard runs without a bar or belt because u and both know u can get away with it for 2 runs....
Just get the trans in the car,drop the sway bar,add the boots/skinnies and pull the seat.I wanna see what that red camaro can really lay down.
The funny thing is your taking it out of your car and putting it in a Vette.Again I dont understand the logic.
Here u have a 450RW setup and u wont run it hard or ***** to the wall?
Why?
Okay, I'll give you the Brent thing, but you gotta realize something here, We are swamped to the max with work right now, ask Tom or Fireball, they stopped by recently and Tom meet our new mechanic and just shook his head at all the work sitting on the floor in boxes, lately, I can't find the time to take a crap let alone start tearing into my daily driver again. I have a serious buyer in SC that wants my motor "as is" he owns a C5 and is paying me handsomley for the engine which it's worth, In replacement, I am dropping in a non forged fly cut 346ci which is ready to go right now with the same cam, but with better heads at the time of removal along with the new trans and vert at that time I guess, I will be on the dyno/track with that package late Aug with maybe more power. I only promised him 440 right off the bat because I know that what they can do in his car along with almost the exact parts I'm running. I hit on a luckey combo, plain and simple thats all.
Joe.
I hit the rev limit,spun,bad trans,ran radials,my underwear was too tight,etc.Come on and get 1[ONE]***** out pass in,no doubt what so ever that a 450 rwhp A4 should run 10.6 to 10.8s[depends on DA]all day and night.I do not doubt you are making the number with your new kick *** package just want to see a good run out of it.
Now remeber, Joe is dynoing the car through a 10 bolt with stock gears, electric reverse flow water pump prototype, shortbelts, etc...he pulled no punches to get the numbers, and this is his "shop" car. Will other cars see these numbers? As joe says EWP is worth at least 11-12 rwhp right there, the yella terras and LS6 block add hp, etc...so right there that is like 20rwhp+ plus the shortbelt that most other cars wont see in my opinion. Joe has had some tranny problems and has been waiting on the replacement tranny for as long time now -- I dont know why he doesnt have it yet but he doesnt.
Joe isnt the only one doing 450rwhp through an A4, but yes I agree it would be nice to see some track times to really prove the point from someone (doesnt have to be joe either).
I am not just blindly supporting anyone either -- as far as I can tell Joe has pretty much abandoned me to getting my car running right myself. I am not happy about it because I entrusted my car to him and didnt want other people working on it, but I am grateful for the kickbutt block he built for me (assuming this oil burning problem is actually a PCV/oil management issue and not a block issue)...I still feel joe knows his stuff and can build the power, even if my car has not yet lived up to expectations.
441rwhp @ 6050 before the clutch popped, 4 bent valves also. 232/238 XER cam 111lsa straight up
Phillip
Phillip
1999 Corvette Coupe
Best bottle pass: 10.68 @ 134.2 1.63 60'
Best motor pass: 11.31 @ 124.6 1.59 60'
TEA 5.3 truck heads 11.75:1 cr, Comp Cams custom bumpstick
I will look in my car to find my last slips from last Thurs night at Atco but I distinctly remember the 1/8 mph was an easy launch of 1.62 93.27 something at just under 7.4 unofficially untill I post in the exact data, but thats still not a fair assessment of my cars performance cause the trans slips/engagues/slips/engagues into 3rd right before the 1/8 and is not working correctly obviously. If thats cause for an uproar, then somoene please come down and install my new trans and vert and I will get it prepped for the track.
The day I put up a post in the engine section claiming "The JPR custom cam S2 head packages are ready for retail and I gaurentte any purchaser of this package the exact same numbers I turned with it" is when I would be out of line, but until then, I am perfectly within the guide lines rules and last but not least, it's my car and my R&D.
Joe.
Are you going to run that motor with the new trans or wait for the 6 speed guy to install it?
Joe.
Phillip
Phillip
1999 Corvette Coupe
My car ran11.14@122.98 at (3460lbs) 4 times 1.47)
My car ran 11.17@121.01 at (3550lbs) 6 times (1.49)
The car was dynoing 429.8RWH/393.6RWT.
These were my final # after a 12-bolt/4.10 install.
I think my # add up just right bro...
Just look at the weight and the mph the car ran.
Oh and are u sure your car weighed 3720 with your 100lb WIFE making that 11.70 pass or was the car alittle more like 3550 at the time
No explanation needed Joe,If your busy with work thats understandable but try and get some runs soon.
I'd really like to see what the red camaro can do bro.
See ya soon
best time 10.9/122,,AT MTI website(blue camaro ss
http://www.motorsporttech.com/customer_rides/index.asp
My car <a href="mailto:ran11.14@122.98">ran11.14@122.98</a> at (3460lbs) 4 times 1.47)
My car ran <a href="mailto:11.17@121.01">ran11.14@122.98">ran11. 14@122.98</a> at (3460lbs) 4 times 1.47)
My car ran <a href="mailto:11.17@121.01</a> at (3550lbs) 6 times (1.49)
sO WHAT DID IT RUN WITH YOUR NEW 441 RWHP?
See ya soon
[/quote]
i have 7000$ to throw in this week ,
what TC and gears i need to get?
what kind of heads and cam ?
where i can get the tunning and instal in dallas?
i wana be in the low 11s N/A and high mid 10s with 150 shot?
sorry for the long write but this my first GM car?
With your auto, you might be able to do a 3000 stall and keep the 2.73's and not loose much et. The 2.73's will help the car dyno higher etc and who knows you might get near 450rwhp. Likewise, go with an efficent converter, I think Yank or Vigilante have coverters that are almost as efficent as a manual. You'll want to ask about gears and converters in the Auto Tranny section for best response.
Some of the folks on this thread should have good insight into the vert & gear thing.
