Changed Bent Rods, Still Probs
I am a noobie to the inside of these engines, I have triple checked the header bolts, seem pretty tight, not sure where to go from here.
It for sure on the passenger side towards the front of the engine, what should I look into next. I know theres tons of threads, but I'm just new to all this and looking for suggestions which way to go, I appreciate it.
Yep, I was at the track on my 4th pass and missed the 2-3 shift. There were 2 push rods on the passenger side, 1 on the driver that I bent. They were not badly bent, but just enough to make it tick.
But now I feel the damage is beyond this.
Are valves hard to change, where do I start?
Drain the oil, pull the plugs, pull the push push rods.... am I looking at putting the car up on blocks for a while while I do this in may garage.
Thanks guys,
.. Changing pushrods are easy and you dont even have to pull the head off. You will need the tool to get your valvesprings off though. Then pull you pr's and roll them across a flat surface. You should find a few bent ones
. Trending Topics
Thanks guys,
Anyhow, I'd also suggest a compression check if you can, or at very least the gas test. If you already checked every pushrod and only found 3 bent ones, then it sounds like it could be valve damage.
Theres a LSX guy in town who's got a shop and is really cool, I'll check with him to see about checking the compression. If that works, then at least I'll know where the problem is. If not, guess its time to put the insurance on hold and break it down.
Its not my DD, but damn, I didn't want it to come to this. The car has just over 80k miles on it, I'm the 5th owner. Guess she has had enough and this is her way of telling me. I'll need to read up now on a rebuild and whats out there to use, might as well do some head, cam, intake work while its all aprt.
Thanks for the help guys, this site is great, real stand-up people, I'm glad I'm on here right now instead of working!
