Compression Test / LeakDown Test Results.....Opinions?
If It didnt ping before the head install, then I would think it could have a slightly bent valve (since air is leaking out of the air filter on leakdown) or its not getting enough fuel due to increased air flow. Does that make sense?
Since I dont know much about tuning software, does the fuel pressure have to be monitored with a guage or can it be done with EFI LIve ?
And with 58 psi fuel pressure my 36# injectors are more like 42#....
Though its not for an F-body, I heard a few times that the LPE pump is better. Though they seem to be the same, people just seem to have better luck witht the LPE kit
Decided to do another leakdown on 5 and 7 cylinders since it seemed to get worse today while I was driving it.
5 was 10% leakage but 7 was 30% leakage and clearly was coming from the oil cap and dip stick tube. I then proceded to squirt oil in the cylinder and it fell to 13%
New motor time
