Compression Test / LeakDown Test Results.....Opinions?
Cranking Compression:
Cylinder-PSI
1-210
2-210
3-210
4-210
5-210
6-180
7-210
8-185
Leak Down Results:
Cylinder-% Leakage
1-14%
2-13%
3-14%
4-11%
5-17%
6-12%
7-18% Air coming out of air filter
8-13%
Hello as well.
If you ran it cold, its possible that you could see better numbers re-running the test.
Since you are running 93 octane, is it only pinging on the spray?
Is is possible you have a mis-matched combo of fuel & N20 jets leaving you too lean?
How many total miles on the short block?
On the top end since you installed the heads?
Did you have to notch the pistons for PTV clearance?
Do you know if the edges of the valve reliefs were smoothed to avoid a hotspot in the chamber?
Sorry for the long list of questions, but I bet that setup runs like a bat outta hell, especially on the spray, and hoping you find the solution.
Might or might not, either way - good luck!
same question - same time. I'd normally say great minds think alike, but I've spent too much time in the Advanced Eng forum and know I'm more average than great...
See, I thought about that and didnt think a dynojet could be loaded but he said he loaded it ?????
SVO 30# injectors on stock pump. My first thought before taking it back to LG for them to look over the tune was that I needed a better fuel pump but Sean said the fuel was fine.
21* timing WOT
