Knock sensor questions
Old Mar 29, 2008 | 10:54 PM
smokinponcho73's Avatar
Default Knock sensor questions
is there any way to test the knock sensor after you have pulled them. I had a knocking noise and somebody said when the knock sensors go out they make a knocking noise. but i heard that after i started to pull it apart Thanks
Old Mar 30, 2008 | 07:54 AM
DaddySS's Avatar
The sensors won't make a knocking noise. There is a test for impedance I believe but after you've pulled the manifold I would sure replace both (and the harness since the plastic clips get brittle with time and heat).
