AFR 225 vs Trick Flow vs ET performance
Old Apr 2, 2008 | 03:09 PM
  #41
DemonSS's Avatar
Thanks guys, alot of great info on this thread.
Old Apr 2, 2008 | 10:50 PM
  #42
2 fast motorsports's Avatar
TFS 215's are the way i went for my radical 348, they flow great!
Old Apr 4, 2008 | 07:00 PM
  #43
aNuBiS's Avatar
Originally Posted by odarabla
This is very untrue. Show me proof of this!! This is a Dyno graph of the AFRs, TFs And ETs. Done by Brian Tooley from total engine air flow. The #'s speak for themself!!
TFS 215 ET 215 AFR 205
RPM TQ HP TQ HP TQ HP
3000 396 226 396 226
3100 396 233 395 233
3200 400 244 399 243
3300 405 255 403 253 400 251
3400 410 265 406 263 401 260
3500 413 275 410 273 408 272
3600 420 288 419 287 415 284
3700 426 300 422 297 420 296
3800 431 312 429 310 425 308
3900 436 324 429 318 429 319
4000 435 331 432 329 428 326
4100 436 340 435 340 431 336
4200 445 356 441 352 438 350
4300 451 369 447 366 444 364
4400 456 382 454 380 449 376
4500 460 394 461 395 458 392
4600 472 413 470 411 463 406
4700 474 424 470 420 466 417
4800 475 434 469 429 468 428
4900 475 443 468 437 465 434
5000 473 450 468 446 463 441
5100 472 458 468 454 464 451
5200 472 467 468 463 461 456
5300 472 476 468 472 462 466
5400 472 485 468 481 459 472
5500 473 495 468 491 461 483
5600 472 503 464 494 459 489
5700 472 512 461 500 458 497
5800 468 517 461 509 454 501
5900 466 524 456 512 452 508
6000 461 526 453 518 449 513
6100 456 530 448 521 444 516
6200 452 533 443 523 438 517
6300 447 536 437 525 431 517
6400 443 540 430 524 426 519
6500 436 539 424 524 418 517
6600 430 541
6700 424 541
6800 418 541
All this really shows me, is that a 205 head is basically keeping pace with its 215 competition.
Old Apr 5, 2008 | 06:04 PM
  #44
sf35thle's Avatar
After more research and talk with ron at vengence racing I think i am going with Trickflow 215cc milled to 59cc. I am probably going with a 228 cam. Something like that should be a good setup with great power low end and midrange
Old Apr 5, 2008 | 06:18 PM
  #45
Kingc8r's Avatar
Tfs Ftmw!
Old Aug 7, 2008 | 03:18 PM
  #46
youguessit's Avatar
I was told by g-force that the trick flows make much more power. They used an extreme example of 70 horses but that was on a 408 motor with the bigger heads... they told me they have used etp heads, afr's and so on. they did tell me they were better on the 215's as well though... Im for trick flows...
Old Aug 7, 2008 | 03:43 PM
  #47
landonew's Avatar
Funny how many people who have yet to do H/C recommend the TFSs and ETPs over the AFRs. I personally own the AFR 205s and a mamo ported 90/90 setup w/ a midsized cam, and i have to say that i love it.
Peak dyno #s are really not all that imporant. I have beat pullied cobras on motor that claim to put down 480+rwhp, and been beat by c6 corvettes that put down 420rwhp. Its the setup as a whole thats important.
More importantly however, dyno numbers are an unreliable bench mark for perfromance. People are under the incorrect assumption that all dynos are correctly calibrated. I have personally witnessed 30rwhp+ descrepencies on dynos within 10 miles of one another. People also do things to trick the dyno such as changing the tire pressure.
Bottom line, I can't give you a side by side comparision between the AFRs or either of the two others so it is difficult for me to make an honest reccomendation. All I can say is that you won't be dissapointed with the AFR 205s. Low end Torque is abundant, throttle response is instantaneous and they make plenty of power up top. Remember, that they are a high velocity head, so don't be fooled if they appear to flow slightly less than the others. They were designed to be a great street head, and thats exactly what they are.
Old Aug 7, 2008 | 04:00 PM
  #48
vettenuts's Avatar
Glad to hear this!!! I have one of Tony's ported FAST 90's and am about to add the AFR 224/228 cam and his massaged heads. I may even bump the cam a degree or two, its low end torque I want, peak number is less important to me.
