Stroking/Boring 5.3L (LM7)
Done a search and there is a similar thread to this but no definitive answer. How much can you bore/stroke this block LM7. it was mentioned that you can bore it .125 to 3.905. Has anyone done this and is this safe.
The block is fully balanced. Attaching to the block will be the top of my current LS1 :LS1 heads, fast 90/90, 232/234/112 comp cam, ud pulley, 1 7/8 headers & twin 3 inch exhaust, hardened pushrods + all the usual bolt ons, built auto and 4200 stall.
My current LS1 is getting tired and my mechanic wants to try something different (different in Australia at least) to see if we can get more out of my current combo. Best so far is 365rwhp with standard LS1.
It is in a 2002 HSV II Clubsport
Cheers
Darren
Know ahead of time that the cost of machine work and new pistons will be twice as expensive as buying a 6.0L. Only build the iron block 5.7L if you have something to prove, otherwise there's better power to be had with the 6.0L for a starting platform.
By the way, not all 5.3L's can go to 3.905. I have one in the trash and one at minimum wall thickness to prove it. When boring over the typical amount, ALWAYS SONIC TEST YOUR BLOCK.
Or sell the 5.3L, don't spend money on sonic testing the block and having new pistons installed and rotating assembly balance, but instead buy a 6.0L and purchase a pre-balanced 408 rotating assembly.
http://www.performancetrucks.net/for...d.php?t=419881
i mean is you really like iron, then you would be better off with a 6.0...
