Flow rate on "stock" size ports...
Old Mar 31, 2008 | 04:48 PM
Red98C5's Avatar
Default Flow rate on "stock" size ports...
I'd like to get info on the flow numbers for the stock unported LS1 heads, like the "806" - "241" - "243" castings. I'm interested in what the stock ports flow on these castings to see how much better aftermarket heads will actually be. Can anybody help?
Old Mar 31, 2008 | 06:08 PM
SOMbitch's Avatar
I think Livernois website shows the comparison. It is by a pretty good margin but the intake runners are bigger than stock so that accounts for some of it.
Old Mar 31, 2008 | 06:17 PM
2xLS1's Avatar
Attached Thumbnails Flow rate on "stock" size ports...-stockls1.jpg   Flow rate on "stock" size ports...-stockls6.jpg
Old Apr 1, 2008 | 09:41 AM
LivernoisMotorsports's Avatar
Here are the flow numbers for a stock 243 casting compared to our CNC stage 2 243 casting with a 220cc intake runner.
Thanks SOMbitch!
Regards,
Rick LeBlanc
Livernois Motorsports
Old Aug 18, 2008 | 02:38 PM
99Ls1fever's Avatar
Thanks SOMbitch!
Regards,
Rick LeBlanc
What LS heads are those that you are comparing??? LS6? or LS1?
Old Aug 18, 2008 | 04:38 PM
FTW's Avatar
FTW
Id say those are Ls6's after looking at the attachments in post 3..
Old Aug 19, 2008 | 06:22 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Also bear in mind since the motor cannot run w/o an intake, the intake is going to be the main determination. I dont think there is a intake out there that flows over 300 thats factory based, i.e. LS1, LS6, FAST (even ported), Typhoon.
Old Aug 19, 2008 | 09:27 AM
99Ls1fever's Avatar
Have you ever seen or found a flow sheet for intakes??? Cause that would be cool..
Old Aug 19, 2008 | 10:13 AM
LS1-450's Avatar
LS1Tech, Gen III External engine stickies, scroll down to letter F. LS1 tech stickies contain a lot of information.
Old Aug 20, 2008 | 03:45 PM
99Ls1fever's Avatar
Also does anyone know what the stock flow numbers are for LQ9 heads and if you have them ported and polished also... so stock flow and ported flow numbers I have been searching every where it seems like to find a dam flow sheet for these things...
