ASP pulley + rollmaster timeing set???
Old Jul 28, 2003 | 11:17 AM
MoesSS's Avatar
Default ASP pulley + rollmaster timeing set???
I just got the timing set and pulley. Do I need to modify the pulley for it to work. I remember reading something about this but I cant find the post. Thanks.
Old Jul 28, 2003 | 01:16 PM
2001CamaroGuy's Avatar
Default Re: ASP pulley + rollmaster timeing set???
nope....just install...
Old Jul 28, 2003 | 01:19 PM
SSCamaro99_3's Avatar
Mine fit fine.
Old Jul 28, 2003 | 01:24 PM
JRcamaroZ28's Avatar
Might have read my post from a while ago. i recived a cam gear that wouldnt fit my cam. It seems that i was the only one it has ever happend to. just to be sure put the gear on your cam and the 2 faces should meet right together. sometimes it can be just the dowel pin on the cam is to big so some drill out the gear a bit.
JR
Old Jul 28, 2003 | 02:46 PM
MoesSS's Avatar
Thanks guys!
Old Jul 28, 2003 | 02:55 PM
Captain Bob's Avatar
I also had an issue with the dowel pin being too tight. just drilled it out slightly and it fit perfectly (I think it was a 1/4 inch bit). My pulley needed the machine work that was mentioned in another post. The stepped part that contacts the front seal was too long and contacted the oil pump. My pulley is about 4 years old and they may have changed the design since then. The work only cost $12 for the pulley and they did it while I waited.
Old Jul 28, 2003 | 02:59 PM
Bowtieman4life's Avatar
IF you use a double roller you need to modify. I'll send you a PM with the info.
Old Jul 28, 2003 | 03:47 PM
DanZ28's Avatar
Ditto!
Old Jul 28, 2003 | 05:49 PM
SStolen's Avatar
Texas Speed and performance rollmaster is 94 and Scoggin dickey's is 85. TSP generally states it is heat-treated (all of it?) and SD states it has a heat treated Torrington bearing. Is there a difference? They are both Rollmaster's....
Old Jul 29, 2003 | 01:43 PM
Constrictor 98TA's Avatar
I installed a Rollmaster Double Roller Timing chain that I bought from Scoggins-Dickey, and an ASP pulley and had absolutely no clearance problems. I did not get the model with the torrington bearing.
Old Jul 29, 2003 | 04:03 PM
DanZ28's Avatar
There must be some serious spec discrepencies between one LS1 to another (or the ASP pulley itself) cause mine wasn't even close nor was two other LS1's here by me. I know people that didn't check and just ran it that way then found on there next cam swap there was grooves in the ASP pulley from hitting the oil pump (not good). Anyway, I'm confused as to why they hit on some and not other's, but I wouldn't just assume that it's gonna work for you without machining. Call TR and ask them why they don't sell double roller's!
Dan
Old Jul 29, 2003 | 06:14 PM
eallanboggs's Avatar
I'm doing the same install right now. Joseph of Texas Speed gave me a good idea. He told me to test mount the ASP Pulley BEFORE installing the timing cover to see if the ASP pulley step contacts the oil pump body. Once the ASP pulley bucks up against the crank sprocket there has to be some clearance between the ASP pulley step and the oil pump body. If they touch you have to mill the step back further. It's worth the extra time to test mount the ASP pulley just to be on the safe side.
Old Jul 29, 2003 | 10:15 PM
XFiveLiter's Avatar
Why doesn't the stock pulley need to be modified for a rollmaster double?
Old Jul 29, 2003 | 11:04 PM
Z 2 L8ter's Avatar
I have the double roller from SDPC with the torrington bearing. The chain fits perfect without any modifying to my ASP crank pulley. I guess everyone has diffrent experiences with the double roller and pulley but mine work great together!
Jeremy
http://community.webshots.com/user/jr3334z28
Old Jul 30, 2003 | 09:51 AM
DanZ28's Avatar
I definately agree, this is how I checked mine. I bet 90% of the people don't even check!
Dan
