How many bolt turns to reach .010-.020 lifter preload???
Re: How many bolt turns to reach .010-.020 lifter preload???
TEA stage one heads are nowhere near perfect for that cam They had the 918s, stock valves and stock hardware.
I asked Brandon about another set a while back and he was too busy, so I found someone to do a custom set just for the cam. There is nothing wrong with TEAs heads. Just there are some others that are flowing stronger at certain points of lift. I was looking for at LEAST 300+ CFM at .600 lift and they couldnt garentee(sp?) that I would see that when I talked to Brian on the phone, so I found someone who could
My motor is nothing special. Stock bore, stock stroke. Its just taking me a long time to get the $$$ to put it together
