Mega Deather Cam Or Ms4
Gabe
Unless you have over 4.10's and at least a 4500 stall I wouldn't run either one, it'll go faster with a smaller cam if you have less gear and stall simply because it will be in it's rpm range more and leave harder.
Why run a cam that makes peak torque at 5000+ if you only have a stock stall, it'll be a pig.
edit: Also.... 2008?? Come on man.
