Cam for stock engine?
Old Jul 29, 2003 | 08:06 PM
Need2gofaster's Avatar
Default Cam for stock engine?
With the mods i have below, what cam would you guys suggest? I want something that will work good with the Nitrous. And i have on order a 3600 tc and 3.73 gears. Streatability is not a major concern since this is not my everyday driver.
Old Jul 29, 2003 | 08:58 PM
Bowtieman4life's Avatar
Default Re: Cam for stock engine?
The gears are only good for a 10th at most ans that's if you had 2.73 gears. Sweet converter. THere's where you'll get the big gain. What ever you do, don't buy a cam that will make peak power over 6,200 rpms. If you shift 400 rpms over the peak you will shift at 6,600 rpms and that is about the max for a 97-00 LS1. 01 and 02 have better rod bolts and should be OK to 6,900.
As far as the cam goes, go wit a reverse split. Nothing over 224. I went with a reverse split 220/220 (trust me its reverse at 200-400) and made 395 RWHP with stock heads and no tuning.
Old Jul 30, 2003 | 11:59 AM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
Here's a couple graphs from our 224R camshaft & our big 232R camshaft. Camshaft selection alot depends on your goals for the car.
http://www.texas-speed.com/dyno224R.jpg
http://www.texas-speed.com/232dyno.jpg
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Jul 30, 2003 | 07:40 PM
thats with stock heads and nothing changed? Wow that is a very large gain. Would i need to change springs or anything?
