23x's cam duration ?'s
What cc heads are you running?
I have 59cc's so I'm looking for something that won't give me ptv issues and be a dd cam. I spoke with SI and they said I might run into some problems but they weren't sure.
Good luck.
Bill
(the 112lsa would make it to tight)So a big thanks go out to John and Terry at FMS for mocking up the setup.
i have made lots of posts about it there is no reason to go huge like a ms3 or ms4 for a daily driver...let me see what i can find...i think the lobe numbers are in one of the threads...
check them all out should help u out tons...https://ls1tech.com/forums/showthrea...t=#post8940586
https://ls1tech.com/forums/showthrea...t=#post8422900
https://ls1tech.com/forums/showthrea...t=#post8419834
Thanks for getting back with me on this. Whats the advantage in having highlift over the regular F13? What numbers did you get with it? I'm torn between this cam, tsp torquer 2, tsp 233/239, tr custom grind. Picking out another cam is a hard decision.
Do it once and do it right so that when your done tune and all you don't start thinking "what if" or "i should'a"
