which cam for my M6? C-1,C-2, or TR Reverse split??
Mike
The low end tq. is great and works well with Nittos. You dont have to leave at a high rpm to get the car to move like the bigger cams .
i absolutely love it. and i would highly recommend it
Comp has at least two 224 cams for the LS1 one is a XE grind that's 224/224 .568 lift the other is a XE-R that's a 224/224 .581 lift. Sometimes it gets a little confusing.
http://members.aol.com/blueflame6469/images/dyno2.jpg
I have seen very few cams on cam only cars that mach mine for area under the curve winthin stock rev limits.
