5.3L questions
My Questions..
1. What is my displacement now that it has been bored .030.
2. (I am a reaaall newb) What does it mean that the crank journals are .010 under. Can I still use a stock crank? I would like to only use new pistons for the bottom end. Use the rest from the donor engine if possible.
3. Where is a good source for parts like bearings, gaskets etc. for this motor.
Here is my car.
My Questions..
2. It means that the crankshaft was ground down a little. The crank had material taken off so it's .010" smaller, so all you need are replacement bearings that are .010" larger. Simple, and common. You should be able to find them.
3. Gaskets at your local autoparts store, I get everything at Napa. Check Summit for the bearings or wait for the guys on here to speak up with a good vendor. I too am actually wondering if there are other places for bearings.
An additional question... I have read on this site in a search to use a Z06 Cam, and I just thought is that the new Z06 (LS7) or the old Z06 (LS6)??
It puts out the exact same curve as an LS1 with no loss of power.
Either way is a good Idea, but if you are going to turbo the motor don't waste your money building it without going with forged bottom end. If you are going to put a different crank in you won't have to worry about the .010, thats only on the crank.
I am going as cheap as possible with this build. I plan on using a diesel turbo off ebay with a little bit o' boost. I thought the stock internals could handle the power? Ive heard the internals withstanding serious boost, no? I was going to run 8-9 pounds of boost. I was only going to get forged pistons and use the rest of the stock stuff.
I have been a fan of the smaller cube motors for a long time anyway. Its been a dream of mine to build a high rev, small cube turbo motor for some time.
