Is it Normal after H/C install?
Old Apr 15, 2008 | 07:45 PM
geovett's Avatar
Question Is it Normal after H/C install?
OK, just did heads, cam, 28#injectors, ls7lifters, ls6oil pump, ls2timing chain, headers, WE JUST STARTED THE CAR OIL PRESURE WENT WAY UP!!!!!! is this normal or do i need to change oil sensor unit??? NEED ADVISE QIUCK......THX
Old Apr 15, 2008 | 08:05 PM
aaron653's Avatar
how high up?...the higher the better imo...definitely better than going way down
Old Apr 15, 2008 | 08:11 PM
geovett's Avatar
dang man, i don't know the machanic called!!!! i guess its way way up!! i pick up car tomorrow.....just don't know what 2 do......i guess he doesn't either.......lol......just thought somebody has gone through this.......
Old Apr 15, 2008 | 08:13 PM
DaddySS's Avatar
We need info - what is warm pressue at idle, 2000 rpm?
Old Apr 15, 2008 | 08:16 PM
geovett's Avatar
Red face
thx 4 asking, don't know, i'll b going to shop in the am do u guys think i should let it warm up before buying new sensor unit....the car only has 39k total miles....
Old Apr 15, 2008 | 08:18 PM
Irocss85's Avatar
well Id take it to a mechanic that has the right adapter tool to read the exact press. it threads on the pan in place of the oil filter. we need to know how high is way way high.
did you also have a new oil pump installed? or did he port it? who knows what it is, but the valve in the oil pump could be stuck?
just to answer the question, no its not normal. I gained roughly 10-15psi after my swap, but I ported the stock pump, and shimmed the spring.
chris
Old Apr 15, 2008 | 08:19 PM
delsold's Avatar
I guess you could also start with the question what was the warm idle pressure BEFORE you did heads and cam? If it was like 30, and now its 45-50 you just helped yourself out, but if its closer to 60-80 you might have created a restriction when installing the lifters and oil pump somewhere.
Old Apr 15, 2008 | 08:21 PM
geovett's Avatar
Red face
yeah the ls6 oil pump is ported.........i don't know if he let it warm up a bit...dang man.....
Old Apr 15, 2008 | 08:22 PM
Shawn MacAnanny's Avatar
What type of oil pump? I got my LPE pump and left the high pressure spring in (there is a high and low pressure spring sent with some pumps) and just cranking my engine over with new autometer gauge and sender i get 55psi. I have yet to start it but expect very high pressure.
Old Apr 15, 2008 | 08:23 PM
Thorny's Avatar
What kind of pump did you put on? Pressure will vary a little from one pump to the next, but if the unit you got had a stiffer/shimmed relief spring it will cause higher pressure at idle, especially when cold.
Old Apr 15, 2008 | 08:26 PM
geovett's Avatar
is 55psi good, or is it high? what can it hurt if its reading high? and will a new sensor b the answer....what else can i do?
Old Apr 15, 2008 | 08:34 PM
My LT1 with 151K on the longblock idles at 30psi and cruises at 40psi. I would think 55psi idling wouldnt be bad and 60-70 psi cruising would be fine. MY Duramax is 80psi cruising cold, 60psi cruising warm and idles around 25psi warm with 184k. I have yet to start my ls1 though.
Old Apr 15, 2008 | 08:44 PM
primer84z's Avatar
The ported LS6 pump will have higher pressure than your stock one. A lot higher. I wouldnt worry about it. Its not unusual to peg the oil gauge with that pump at WOT.
geovett's Avatar
thx 4 that info.....i just know what to expect......maybe somebody else has more info...........so i don't need to panic.......lol......should wait and see maybe drive it what ya think????................:conf used:
Old Apr 15, 2008 | 08:46 PM
sf35thle's Avatar
Just wait and see and keep us updated
Old Apr 15, 2008 | 08:50 PM
geovett's Avatar
Wink
sure will, dang man i thought i read something about this before....just don't remember what was done...................confused in souther Ca....LAND OF THE BLESSED!!!!!!!
thank brothers..............truly we r bro's
Old Apr 15, 2008 | 08:55 PM
01FbTaWs6's Avatar
I just put on the LPE pump, with high pressure spring too, and it sets right about 70 psi at idle. Its fine. Once im at WOT, the gauge is pegged.
Old Apr 15, 2008 | 09:02 PM
geovett's Avatar
Cool
thats good info................thx
Old Apr 15, 2008 | 09:09 PM
Brent@LPE's Avatar
55# at cold Idle you are looking good ... 70 # at idle and pegging the gauge I would worry about.
Brent
Old Apr 15, 2008 | 09:19 PM
geovett's Avatar
Red face
thx bro, i'll b checking that tomorrow!!!!!! what if it does peg at 70 at idle whats my next move.......................... still confused in southern ca......
