Started the rebuild
Old Apr 16, 2008 | 09:36 PM
ExceSSive's Avatar
Default Started the rebuild
This is my rebuild of my 2002 Camaro SS. I blew the #7 piston Oct. 5, 2007. This is the documentation of the new 408 motor, moser rear and performabuilt trans. Check out my fQuick webpage JDmurse is my username. Sorry not digital camera savvy so don't know how to shrink pics.
There is info about my setup in this Link
The old rear is out
The new Moser 3.42 rear with TrueTrac in, waiting on the new panhard rod and swaybar that are on the way.
Filling it with fluids
The new UMI torque are (thanks for hooking me up xXx)
Old motor out
New motor prep/paint
First coat done
Ridin' dirty or white n' nerdy
The shoe horn maneuver
Getting those mount bolts through
And it is in... :bed: does it feel good!
Covering it up to keep critters out until it is buttoned up
Will update the thread as progress is made. Thanks for checking it out.
Jon
Old Apr 16, 2008 | 09:41 PM
ExceSSive's Avatar
Here I had to clean, scrape and sand the engine bay. I then repainted it.
Further updates soon...Hope to finish this weekend
Old Apr 17, 2008 | 02:40 PM
ExceSSive's Avatar
Funniest thing when I was dropping the motor in my wife asks me why I did not sell the AFR 205s and buy some AFR 225s? I probably would have gone 235s if you can get them (yet) or just some Mamofied 225s. I did not do it because I thought she might get upset after all the money I spent so far on the build...go figure. I did not think she would even realize the difference the 225s would make over the 205s. Thinking about it now I could have sent my 205s to Tony and had him check my valves and do his thing on them...probably would have been better for my motor than the 225s because I rarely see the track anyway.
Nothing happening on the build today, waiting on Yank to send back my TC.
Old Apr 17, 2008 | 02:56 PM
ChrisH821's Avatar
Nice progress, might I ask what you are doing for cam?
Also it would probably be a good idea to invest in some jackstands.
Old Apr 17, 2008 | 03:40 PM
Schitzo's Avatar
looks good. You might want to cap that drier
Old Apr 17, 2008 | 03:50 PM
ExceSSive's Avatar
Thanks guys.
The cam is from HKE (also motor builder) it is 242/244 .610/.612 113+3.
I have jack stands, if you are referring to the shot filling the rear diff cover they were under the subframes, you can actually see the base of one in the torque arm pic. I would not be under there without the jackstands even with the floor jack there.
Old Apr 17, 2008 | 04:00 PM
99blancoSS's Avatar
Very nice!
If someone is looking for this setup please get a hold of me.
Old Apr 17, 2008 | 04:28 PM
prochargedchevyi's Avatar
I can't believe you got your wife to help you paint your block.
My wife would have kicked me in the ***** and taken my wallet.
Old Apr 17, 2008 | 04:34 PM
therobman's Avatar
nice setup i blew #7 also stock motor 37000 miles sucks but i got it runnin now this cars gunna be sickkk
Old Apr 17, 2008 | 07:07 PM
ExceSSive's Avatar
I had 35k miles when it blew...definitely exerts negative pressure (sucks).
My wife has been great about this whole build, helping with what she can, and giving the go ahead with a smile on all purchases. I wish I had known that she would have approved a new set of heads but since my heads only had 1000 miles on them I did not even broach the subject.
Old Apr 17, 2008 | 11:05 PM
byler900f's Avatar
looking good! keep them coming!
Old Apr 17, 2008 | 11:24 PM
RoDan's Avatar
nice, lookin good!
Old Apr 18, 2008 | 01:08 AM
ChrisH821's Avatar
lol, oh yeah there it is. disregard... Should be killer when its done. nice work.
Old Apr 18, 2008 | 03:22 PM
ExceSSive's Avatar
New panhard rod is installed now...waiting on swaybar and torque converter should be here Monday.
Old Apr 21, 2008 | 08:45 PM
ExceSSive's Avatar
Well today I installed: Flex plate (no pic), AC condensor, PS pump pulley, crank pulley, water pump, radiator and some other odds and ends. The tranny goes in tomorrow...will be a biatch by myself with the jack but you gotta do...
[img]https://i295.photobucket.com/albums/mm155/JDmurse/Thecleanuppaintandinstall029
Old Apr 22, 2008 | 07:41 PM
ExceSSive's Avatar
I ended up not getting it installed today but I did get it put together, my rear swaybar showed up too. I had to take my daughter to guitar lessons after going to work for a couple of hours...I have not been paid for my TDY yet and filled out the TV on 3 Apr...not gonna go into why, but I had to take care of this as my Gov. card is due and it is $2300 and has not been paid. I am probably going to have to pay it and then just cancel the split dispersement or something. Slowed my progress today considerably.
Old Apr 23, 2008 | 12:40 PM
white99's Avatar
What did you use to clean all that battery acid with? Did you repaint it with factory paint or what? Mine looks a little worse than what yours looked like.
Old Apr 23, 2008 | 01:06 PM
tylerdj's Avatar
Very good looking setup!
Old Apr 23, 2008 | 01:12 PM
99blancoSS's Avatar
Nice ps pulley, is that from Revxtreme? (sorry if you answered it already)
Old Apr 23, 2008 | 06:53 PM
ExceSSive's Avatar
Thanks guys
No the pulley is from Lingenfelter...
white99 What did you use to clean all that battery acid with? Did you repaint it with factory paint or what? Mine looks a little worse than what yours looked like.
I sanded with 60/120/200/600 paper and the used some of the metal ready from POR 15 that I had left over. Then I did repaint it. I just used some duplicolor from Autozone. I did not care if it matched perfectly because it is under the battery tray and the rest is on the firewall.
23 April '08
As for the Update...today I installed the transmission and DS loop. Tomorrow I uninstall the transmission and DS loop and then re-install the transmission and DS loop.
I installed the trans and the TC slipped off the shaft (slightly) so the crank won't turn . It was a PITA doing it by myself and now I have to undo it and re-do it. I don't feel much like posting pictures right now. Maybe later.
Jon
