LS6 cam -VS- LS1 hot cam
Can some please tell me the difference between the 2? And how much power would you get from either of these. With the Hot Cam, does anything need to be changed and how much computer work you need??? thanks for the help
They are pretty different cams. The Hotcam has a lower lift (.525?) VS the Zo6 (.550?). The Hotcam is also on 112 LSA and will idle much much rougher than the Z06 cam (much higher LSA 116.5?). You should swap valvesprings for either cam. The Hotcam will require more tuning.
-Nick
-Nick
