Do i NEED new lifters
Right now i am running a Comp 217 226 with comp 981 springs and chromolly pushrods. Do i need new lifters to put in a 232 236 576* 578* 112 LSA? Or is everything ok to just slide it in?
If you're just doing cam with 578 lift you probably won't need lifters. The two jobs are almost completely separate and pulling the heads is no minor task, so I would slide it in, then if you need lifters go ahead and do that job.
