Trick Flow 235cc vs. LS7 head
Old May 1, 2008 | 10:01 PM
  #61
un17real's Avatar
Originally Posted by Stang's Bane
I applaud your efforts.
But this test is not true test of cylinder heads.
As everyone should know, a camshaft should be matched to a cylinder head. If you were testing a TFS 225 vs a ETP 225 then I would be on board with you. As it is you have a cam that is proven to generate big numbers with you heads and you stick it with a head that will want a completely different set of valve events. Honestly I am shocked that the LS7 heads did this good. Brian Tooley and I had a conversation about this several months ago and he said a test of this sort was in the works. I asked him then to please run a different cam on the ls7 heads than the TFS stuff.
I propose one more test. Very simple. Run the Katech/GM cam in this same motor. Either one will work, either the 220/244 or the 233/276. These are not magic cams or secret in any way. I would be interested in what the results were then.
I would <3 too prove this wrong and strap up a set of these heads up on my whip and even take it down too the track too back up my theory
Old May 1, 2008 | 10:04 PM
  #62
3fingas's Avatar
Originally Posted by Pray
I am running a 416 with a XER 244/248 .612/.615 114+4. I degreed it in on a 109.7 ICL. I am going to run 12.01:1 SCR and 8.63:1 DCR, 67cc, Cometic 4.085" bore, .045" thickness. I have Ron's ported 90/90, YT's, UD. I am going to be running the LG Pro's with Borla Stingers that were off of Tony Mamo's car. They have been modified some, basicly because I am out of money. I also wanted to get Pat G to spec me up another cam, but again, out of money. So I am pretty much stuck with what I have. I would really like to see 550/525rw. That is the goal in the end. This motor will also be going in a daily driven 02 Z06. I will be happy if I see 525/500rw in it current configuration.
Brett
Walked in on a friend eng dyno'ing his cnc/cam ls7 . Made little over 620 with a torquer think it was 220/244 .61? think its a katech sure its searchable. Anyway sounded very sleepish.
As far as TFS, excellent R&D, Just more data to soak up.. Keep up the good work!
Old May 20, 2008 | 08:19 AM
  #63
TrickFlowTech's Avatar
LS1Tech Sponsor
Default More results
This graph shows the same work up but with the GM cam.
Cam Specs are: 233/276 ( the cam actually measures 236/278 @ .050) .629/.629 lift with 1.8 ratio rockers. 107 lope seperation. We used the 1.7 Jesel rockers on our head which give .595 lift.
__________________
Old May 20, 2008 | 08:27 AM
  #64
Stang's Bane's Avatar
Crow has been eaten...
Old May 20, 2008 | 08:29 AM
  #65
briannutter's Avatar
But being a MAN with crow in his belly is better than being a weiner. I respect you for saying it.
Old May 20, 2008 | 08:31 AM
  #66
Thanks Brian. I do have to say that it some of the most bitter crow I have ever eaten though. And I have eaten ALOT!!! LOL
EDIT: I did say people would be surprised, I just didn't think it would be me!!!!!!!
Old May 20, 2008 | 09:01 AM
  #67
2002gt's Avatar
Looking at this graph, I am so glad I picked trickflow 235cc for my Vengeance Racing 440 build. Numbers soon
Old May 20, 2008 | 10:38 AM
  #68
Mike@TEA's Avatar
That is awesome. I applaud the guys over at Trickflow for spending the extra time, money, and manhours to go back and run the other camshaft just to "find out". I hope to see more of these type of test's in the future!
Old May 20, 2008 | 11:12 AM
  #69
Brian Tooley Racing's Avatar
Amen, Cudos to TFS!
If I'm looking at this correctly, the GM cam on the TFS heads makes almost 600 TQ at 4500 RPM, which is up almost 50 lb ft, and the peak horsepower is not down very much? I would love to see a graph of the TFS heads overlaid with both cams.
A shop once told me they put a smaller cam in place of a larger cam in a 440 cu in TFS 235 headed engine and it didn't lose much peak, but gained TQ everywhere.
Old May 20, 2008 | 11:32 AM
  #70
LS1Tech Sponsor
Thanks guys.
Look for more up and coming test results.
__________________
Old May 20, 2008 | 12:06 PM
  #71
racer7088's Avatar
Thumbs up
Damn I am surprised as well but the TFS 235s we've used so far have really run well that's certainly true. If there was a little shorter and larger runner manifold the TFS would even run better probably but still very impressive and great results all through the midrange and down low comparitively.
Old May 20, 2008 | 02:35 PM
  #72
MPM IV's Avatar
Originally Posted by Brian Tooley
Amen, Cudos to TFS!
I agree and appreciate the effort to check the other cam. I would also like to see the two cam graphs overlayed. Congrats on the great results.
Old May 20, 2008 | 08:34 PM
  #73
Greg Fell's Avatar
i'd love to see an overlay of the 2 cams with the tfs heads as well!!!
Old May 20, 2008 | 10:04 PM
  #74
Bill00Formula's Avatar
It seems like the Trick Flows are great heads, in fact I am thinking about getting them. But it does seem like there are a fair amount of Z06's that are getting 540-575 rwhp with cam only and 575-625 rwhp with cam/ported heads.
It just seems like the non LS7 headed cars need really high compression/more cubic inches to get similar results.
Old May 22, 2008 | 12:39 AM
  #75
DanZ28's Avatar
Amen, Cudos to TFS!
Ditto what these guys said!
Thanks for sharing, interesting thread..
Old May 27, 2008 | 07:59 PM
  #76
1SICKBIRD's Avatar
Are those the GM cnc ls7 heads or the standard ones?
Old Jun 3, 2008 | 09:01 PM
  #77
Howie Felterbush's Avatar
Originally Posted by AMERICAN_HP
How in the world did you come to that conclusion??? Because of the few extra HP at the last couple hundred RPM?? I understand its almost 50hp at 7K, but you just wouldnt shift the lower hp car at that rpm.
Drag races are won/lost based off of highest average HP, and power delivery in the given RPM range.
Based off of the graph, the car with the lower HP and torque would have a significant lead by the time the higher hp/tq allowed the other car to gain momentum on the big end..
I would take the couple less HP any day of the week, based off of the power under the curve..IMHO
If a car is making more HP up top and shifts later and falls back into an area that still is making more power then the lower peaking head, you bet your *** the higher hp head extending RPM out later will WALK all over the lower HP head with less rpm range. You can't be seriously trying to argue this....
Average power means NADA except for driveability. All of that is wiped clean the moment the car goes WOT and the gears are changed and suited for each RPM band. The LS7's will breathe longer. RPM=MPH!!!
Old Jun 3, 2008 | 09:04 PM
  #78
I'd like to believe they are the standard CNC which has NO where near the R&D the TFS heads finally came out to after close to 1.5 years of "perfection"
Old Jun 3, 2008 | 09:10 PM
  #79
Greg Fell's Avatar
i meant, avg power over all the usable range from wot to redline (shift and calc next gear). example, in excel, i've calculated this before by using the gearing values (ie if shift at 7k, start avg/counting from the next rpm after shift), entering a dyno run (hp vs rpm), and avg over 1-4th gear (2/3/4 start where shift would drop it to).
Also, 3-5500 is an absolute *** tearing exp with the big tq, in addition to up top.
I like LS7 heads, but with sheetmetal and a solid roller. Then you'd see the big flow numbers shine. Til then...my TFS treating me real good.
Old Jun 4, 2008 | 05:25 PM
  #80
john_sblendorio's Avatar
How does this all change in a blown application?
