Trick Flow 235cc vs. LS7 head
Old Jun 4, 2008 | 07:24 PM
  #81
racer7088's Avatar
Thumbs up
Originally Posted by john_sblendorio
How does this all change in a blown application?
John,
I don't think it would change much except the exhaust becomes more important then. The larger you make an intake port and valve the less duration you need to fill a given cylinder at a given rpm. The LS7 has a much bigger intake port and valve so it can run extremely well even with a tiny cam such as the way it does in OEM form still making 450 RWHP with a tiny cam. On the exhaust side of a blower engine you need a better port than on an NA since you are now expecting it to pass much more exhaust than before.
Old Aug 27, 2008 | 04:51 PM
  #82
nahasapeemapetalon's Avatar
Why did the TFS heads die at 6300? Not enough flow? Would 245's drop off a few hundred rpms later?
Old Aug 27, 2008 | 05:19 PM
  #83
Greg Fell's Avatar
manifold
Old Sep 27, 2008 | 10:37 AM
  #84
Greg Fell's Avatar
Originally Posted by Bill00Formula
It seems like the Trick Flows are great heads, in fact I am thinking about getting them. But it does seem like there are a fair amount of Z06's that are getting 540-575 rwhp with cam only and 575-625 rwhp with cam/ported heads.
It just seems like the non LS7 headed cars need really high compression/more cubic inches to get similar results.
keep in mind those same ls7 zo6's have a dry sump and titanium internals...that is worth rwhp.
