Stock Lifters ok?
I have also run Comp R lifters but frankly I don't think they 'pump up hard' like Comp says. I think they work like stock. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
But your stockers should be fine...
<strong> Thanks for the input! How do you take the stock lifters out....any procedures out there? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Its pretty easy. Once you have the heads off you will see 2 rectangular lifter guides each held in by a 10 mm bolt. Take out the bolt then slowly remove the guides, making sure the lifters don't come out with them. With the guides out of the way you can just use a stick magnet to start pulling the lifters out. Go easy pulling them out, and make sure you keep them in order.
Good Luck
Just make sure you don't have any debris on them when you put them back in. I had one of my stock lifters collapse because of caked gunk inside.
Good Luck
