Reusing old parts in rebuild
Old 08-03-2003, 03:04 AM
blu00rdstr's Avatar
Default Reusing old parts in rebuild
Can most parts be reused on a motor rebuild?
I'm considering reusing the following parts in a forged bottom end 12psi supercharged motor. These parts are from an LS1 with 30Kmi. Is there any reason to replace any of the following?
    Old 08-03-2003, 03:11 AM
    MASS seller approved
    Time2Kill's Avatar
    Default Re: Reusing old parts in rebuild
    I'd replace timing chain and gears if you are still using the stock setup. Stock setup has some slack in it. I'd also replace flywheel bolts, can never be too safe!
    As long as the engine is out of the car, definately put in poly engine mounts!
    Old 08-03-2003, 01:31 PM
    blu00rdstr's Avatar
    Thanks!
    I didn't know stock timing gear and chain has slack. I wonder why some people think it's necessary to replace the stock setup with double-rollers.
    Are the flywheel bolts torque to yield also?
    Old 08-03-2003, 02:49 PM
    strokedls1's Avatar
    Stock chain has a lot of slop. I would go with the heavy duty rollmaster single row chain. Easier to install (no oil pump clearence or asp pulley problems. I assume you are doing new springs. Pushrods should be replaced if they are still stock. Everything else can be reused.
    Old 08-03-2003, 03:03 PM
    Scalpel's Avatar
    Thanks!
    No, they're not TTY bolts.
    Old 08-03-2003, 05:10 PM
    blu00rdstr's Avatar
    OK, I'll search for single-roller chain setup. If flywheel bolts are not TTY, then I'll reuse those.
    The heads are from A&A, and have dual springs. What's wrong with stock pushrods? I am reusing the roller lifters and the plastic guides.
    Old 08-03-2003, 05:23 PM
    99 Black Bird T/A's Avatar
    Received 1,440 Likes on 998 Posts
    Timing chain and gears - stock is weak, Rollmaster makes an excellent double roller
    pushrods - they are weak easy to bend. They also flex more than stiff pushrods. Flexing pushrods don't help control the valve train.
    Old 08-13-2003, 11:49 AM
    blu00rdstr's Avatar
    You guys convinced me. I bought Manley pushrods, ARP 12-pt head studs and ARP main studs, and rollmaster double-roller.
    Old 08-13-2003, 07:50 PM
    Chubby's Avatar
    would it be a problem to reuse the cam?
    Greg
    Old 08-13-2003, 07:59 PM
    LS1Tech Co-Founder
    Pro Stock John's Avatar
    Received 1,121 Likes on 733 Posts
    FINE Crank
    REPLACE Timing chain and gears
    FINE Flywheel, shaft connector, and bolts
    FINE Water pump
    FINE Front cover, rear cover, valley cover, oil pan
    FINE Rollers, roller guides,
    REPLACEpushrods
    REPLACE Engine mounts (I went poly)
    FINE Electrical Sensors
    Old 08-14-2003, 12:04 PM
    blu00rdstr's Avatar
    What's wrong with stock engine mounts? Is there something specific to F-body mounts, or are C5 engine mounts the same?
    Old 08-14-2003, 12:09 PM
    LS1Tech Co-Founder
    Stock f-car motor mounts are pretty soft. No idea with C5.
    Quick Reply: Reusing old parts in rebuild
