TSP Stg 2.5 LS6 Heads vs. Stg 2.5R 5.3l Heads for my set-up?
Old 04-27-2008, 01:59 PM
LS1C5Vette's Avatar
Default TSP Stg 2.5 LS6 Heads vs. Stg 2.5R 5.3l Heads for my set-up?
Did a search and did not come up with any good info, I am not really looking for power under the curve here, I already have a 233/239 112 cam and now I need some heads, which ones would suit my needs and get me more power?
or
TSP Stg 2.5 5.3l Heads
I do not want to flycut and more compression would be nice. Thanks in advance
Old 04-27-2008, 02:04 PM
SpeedWorld's Avatar
I would go with the 5.3 stage 2.5 heads. I have seen only good numbers with similar cams like yours!
Old 04-27-2008, 03:20 PM
LS1C5Vette's Avatar
Would I have to flycut with their new 2.5R heads?
Old 04-27-2008, 11:54 PM
LS1C5Vette's Avatar
ttttttttttt
Old 04-28-2008, 12:09 AM
Midnight02's Avatar
I just finished making the exact same decision. There seems to be a TON of people running the 5.3L heads and most of those people have had very positive results....I ended up going with the 5.3's milled to 60 cc. From the flow data, it looks like the LS6 heads flow a bit better up top and would probably net you a few more HP up top, however I was more comfortable with the 5.3's simply because there was more information available on them.
As for the flycutting question, I'd contact TSP and hopefully they can give you some guidance there.
Old 04-28-2008, 12:46 AM
LS1C5Vette's Avatar
^^ Thanks man
Old 04-28-2008, 01:25 PM
LS1C5Vette's Avatar
anyone else?
Old 04-28-2008, 04:44 PM
RyderTA's Avatar
I have their 5.3's and they're nice! I'm debating taking them off and milling a bit but you can't go wrong either way.
Old 04-28-2008, 11:19 PM
'02SOMz28's Avatar
5.3 all the way
Old 04-29-2008, 07:38 AM
teke184's Avatar
"I am not really looking for power under the curve here"
so all you want is peak power number...then go with the heads that have the best high lift flow numbers and biggest intake runner.
should make a nice dyno queen
Old 04-29-2008, 01:32 PM
LS1C5Vette's Avatar
I take it the 2.5 ls6 has a bigger runner than the 2.5 "R" 5.3l heads?
Old 04-29-2008, 10:40 PM
eamador11's Avatar
I agree, thats not the way to plan for your ride. You always want the best power under the curve, otherwise youl only have fun at redline only.
Old 04-29-2008, 10:43 PM
AaronR's Avatar
You will get more power from added compression than a few CFM.Theres probably little to no difference anyway in actual flow numbers of these heads.
Old 04-30-2008, 08:28 AM
john563's Avatar
I have the stage 2.5 5.3 heads with a custom pat G cam 232/238 6xx 6xx 111LSA+2
No flycut needed..In an A4 I put down 435rwhp 407rwt..My old numbers with a 224cam was 417rwhp 407rwt..I thought I would lose lowend going with this cam but it does not feel much different down low..It screams mid range and up top LOL!!!
Old 04-30-2008, 01:55 PM
LS1C5Vette's Avatar
Thanks for the help guys, I think I am going to spring for the stg 2.5 5.3l R heads for the added compression over the ls6
Old 05-02-2008, 12:34 AM
mrtosh's Avatar
There are plenty of guys in the dyno section running the MS3 w/the 2.5 5.3 heads w/no flycutting needed. Even Johnjanz@texasspeed is running that combo and states no flycutting required... Go for the 5.3's. That's my next investment
Old 05-02-2008, 12:43 AM
bigpapi211's Avatar
either way you can't go wrong just gotta decide what your doing after that.
Old 06-19-2008, 09:04 PM
LS1C5Vette's Avatar
Guys what about the Stg 1.0 LS6 heads, who is running these heads???
