upgrade injectors?
Old Apr 28, 2008 | 11:17 AM
firechicken76's Avatar
Default upgrade injectors?
im doing a buildup on my ls1, patriot stage 2 heads, 230/230 cam, fast 90 intake/ 90mm NW tb, headers. should i upgrade my injectors? if so what do ppl suggest i use?
Old Apr 28, 2008 | 11:21 AM
stevied916's Avatar
yes. You could probabally get away with the 30# ford red tops for pretty cheap
Old Apr 28, 2008 | 11:39 AM
tylerdj's Avatar
I agree, some 30# would benefit you.
Old Apr 28, 2008 | 11:46 AM
s346k's Avatar
gtp injectors
i see some for sale on here for $260? is that about how much they go for?
Old Apr 28, 2008 | 11:47 AM
Originally Posted by s346k
gtp injectors
gtp? tell me more about them
Old Apr 28, 2008 | 12:07 PM
stevied916's Avatar
You can probabally find some used ones cheaper. I bought some from a good friend with 3000 miles for $90 but that was a really good deal
Old Apr 28, 2008 | 12:52 PM
s346k's Avatar
the later model stock s/c gtp injectors come out to be ~39lb @ ls1 fuel pressure (58 psi i believe)...they can be had CHEAP on the gtp forums, but you have to buy 2 sets because there are only 6 to a set haha. maybe check ebay? that would be my suggestion. they will work jut fine, a friend of mine is using them with a tfs 215 head/donkey dick cam/fast 90 setup with NO problems.
Old Apr 28, 2008 | 01:10 PM
MJD's Avatar
MJD
Let your tuner check your duty cycle before buying injectors. Why upgrade if you don't need them?
Old Apr 29, 2008 | 03:12 PM
Bill Bowling's Avatar
I have the mods listed below. I went with #42 injectors from stock.
My duty cycle was over 85%. Now it runs around 50%. I bought mine from HSW at a good price.
Bill
Old Apr 29, 2008 | 03:47 PM
YellowToy/A's Avatar
Get the green top 42lbs. You will need them. Make sure you get a tune before you drive with the new injectors. It will be way to rich and you will wash the cyl walls
Old Apr 29, 2008 | 05:36 PM
davered00ss's Avatar
Moderator
#30 ford SVO red top injectors. <$300. You will need them with those mods. You need to put them on at the place that is going to tune your car for them. You can't change injectors and not have it tunned right away.
Old Apr 29, 2008 | 05:38 PM
MeentSS02's Avatar
Kleeborp the Moderator™
If your setup is worth jack ****, you'll need the injectors. I wouldn't wait to find out either...
Old Apr 30, 2008 | 12:00 AM
96ta's Avatar
yea id def. say youd need injectors. im not down for just trying to get by on stuff. so id say go with 45lbsers
