new motor, low oil pressure??
Old 04-28-2008, 11:22 PM
D'scamaro's Avatar
Default new motor, low oil pressure??
i just put in my new 408 and when i drive it down the street at about 3500 rpm's i only have about 45 psi and after my motor warms up, it drops below 40 at 3500 rpm's... what can it be?? im ready to get it right, ive waited a long time to get this motor!!
Old 04-29-2008, 12:24 AM
Prerun4fun13's Avatar
Pull the front timing cover check the oil pump o ring. Also is your oil pump new and or a ported unit?
Old 04-29-2008, 10:15 PM
D'scamaro's Avatar
it is a new ported ls6 oil pump... i was thinking about buying a used ported oil pump so i know that it works.. and what if i do check the o-ring and the oil press is still low? i already checked to see if the plug was in the back of the block and it was. where would i go next?
Old 04-29-2008, 10:25 PM
eamador11's Avatar
yeah very common to pinch the oil ring when re-installing the pump. or its torn
Old 04-30-2008, 11:06 AM
D'scamaro's Avatar
should i also go ahead and get a used oil pump that i know works or just get a new one?
Old 04-30-2008, 11:10 AM
sweet-94z28's Avatar
Get a new one!!!!
Old 05-06-2008, 10:17 PM
D'scamaro's Avatar
what else can i check for while i have it torn down? anything else that could be cause that??
Old 05-12-2008, 11:25 AM
D'scamaro's Avatar
any suggestions on where to get the oil pump from?
Old 05-12-2008, 12:36 PM
bjamick's Avatar
Texas speed is where I bought most of my stuff. They have quality parts and are usually cheaper also. But usually its the O ring that causes low oil pressure.
