Rocker Arm Install..?
Old May 2, 2008 | 03:36 AM
wormy01SS's Avatar
Default Rocker Arm Install..?
I was wondering if there was any way to keep the rocker arms from twisting as you tighten them down or if it was just something that is going to happen?
Old May 2, 2008 | 04:59 AM
slowec's Avatar
I hold em steady with one hand and use a 1/4" air ratchet in the other. Then torque to spec. There is a sequence and procedure you are supposed to use. Find TDC. Tighten certain ones , spin the crank 360 and torgue the others. I wonder how many people on here actually follow it. Some local guys watching me do it the other day were sayin they have never heard of that and they have done cams before
Good luck.
Old May 2, 2008 | 05:24 AM
vettenuts's Avatar
Here's the procedure:
Old May 2, 2008 | 05:33 AM
MeentSS02's Avatar
Kleeborp the Moderator™
The above is the procedure I followed with my recently rebuilt stockers by Harland Sharp. I held them with one hand while tightening with the other, but once you get to a certain point, they kinda just straighten themselves out.
Old May 2, 2008 | 11:50 AM
wormy01SS's Avatar
Thanks fellows
Old May 2, 2008 | 01:51 PM
Fratsit's Avatar
I used the precedure that vettenuts posted.
R/
Frat
Old May 3, 2008 | 11:47 PM
wkdws6's Avatar
which is exhaust valve rocker?
Old May 4, 2008 | 09:05 AM
Viper's Avatar
If you're looking down on the head, it is the one that goes above the exhaust port; it will line up with where the header attaches to the head (the primary tube).
Old May 4, 2008 | 10:30 AM
socmguy's Avatar
Restricted User
very good info, thanks for sharing!
Old May 4, 2008 | 11:59 AM
jimmy1981's Avatar
I have tightened all mine at the same time.
What is wrong with that?
Old May 4, 2008 | 12:01 PM
davered00ss's Avatar
Moderator
Originally Posted by Fratsit
I used the precedure that vettenuts postes.
R/
Frat
Me too.
I holdt he rockers in place with one hand.
Old May 4, 2008 | 12:46 PM
vettenuts's Avatar
If you do it that way, those rockers on the cam lobe (partially or fully open) have incorrect bolt preload, even worse with stiffer aftermarket springs. You also risk aluminum thread damage.
Old May 4, 2008 | 01:46 PM
jimmy1981's Avatar
Originally Posted by vettenuts
If you do it that way, those rockers on the cam lobe (partially or fully open) have incorrect preload, even worse with stiffer aftermarket springs. You also risk aluminum thread damage.
Maybe this can explain why I have some odd valvtrain noise?
Old May 4, 2008 | 09:14 PM
vettenuts's Avatar
I should clarify, I meant bolt preload not lifter preload. I fixed the original post to clarify.
