TR 224 with stock heads Pushrod length???
The TR224 is probably the most common cam out there. 7.4 is what you need. Once you mill heads, checking pushrod length is necessary.
I ran 7.4's with stock heads, and I run 7.35's with my AFR 205's milled 0.030 and a stock GM gasket. I did check the pushrod length and valve lash. (actually Slowhawk did
with me) The TR224 is probably the most common cam out there. 7.4 is what you need. Once you mill heads, checking pushrod length is necessary.
with me)
