newbie question on ECT sensor
Old May 5, 2008 | 09:17 PM
demonpixel's Avatar
Default newbie question on ECT sensor
about to start my first engine build; 98 LS1 block with 853 heads. i have yet again a few more newb questions.
if 853 heads appeared on LS1s from 99-00, and i have a 98 pcm, will a 98 ECT sensor fit on an 853 head? If not, will a 99 ECT sensor be compatible with my 98 pcm?
last q, i assume i can get these sensors from an auto parts store like oreilly's or napa correct?
thanks again guys
Old May 6, 2008 | 01:39 AM
Jantzer98SS's Avatar
The 98 sensor is a different thread size than the 99+. I just ran into this problem on my 98 with 02 heads. Either get an adapter for you 98 sensor or since I wasn't using the third wire for the guage, I just used a new style sensor and wired it up with the other two wires. I will know friday if it works, but I'm sure it will.
Old May 6, 2008 | 12:44 PM
demonpixel's Avatar
cool thanks man I'll check back with ya this weekend to see if what ya did worked
Old May 6, 2008 | 02:55 PM
67rsss's Avatar
Demon, DIdn't realize the 98 Sensor is a different thread size!
Old May 7, 2008 | 07:49 AM
demonpixel's Avatar
Makes two of us, 67.
So is the adapter going to be an NPT pipe thread? Would anyone happen to know what size threads so I don't have to make multiple trips to the hardware store?
