? about 5.3 heads vs 5.7
I hope you're not planning on that being a pump gas motor. You'll still have to mill the hell out of 5.3L heads to get to 12.5:1. Then you'll have to watch out because any decent cam wont fit without cutting the pistons.
i am going with a forged bottm endwith higher compression pistons, so i won have to mill the hell out of them, and i know its not a pump gas motor.
question is, is the combustion chamber any different so its easier to get the higher compression? should i just go with 5.3's or mill my already ported 5.7's
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Keep the heads now and use the pistons to get you to the CR that you want. The only reason people mill heads is because its cheaper than buying a whole new short block when they dont need it, but since your already taking care of that just get a set of domed pistons.
