Oil Change Light?
Old May 11, 2008 | 11:04 AM
ChrisUlrich's Avatar
Default Oil Change Light?
After my header install, the oil change light keeps coming on? I have good oil pressure and I added 5 1/2 quarts of Pennzoil 10w 30. It goes off, but then it comes back on.
My dipstick is kinda broken so I can't see how full it is. haha Any suggestions?
Old May 11, 2008 | 11:26 AM
neeshSS's Avatar
Is it like every time you start the car it stays on for a few mins then shuts off?
Old May 11, 2008 | 11:53 AM
Bill Bowling's Avatar
You need to reset the light. Turn the key on and hold the trip button for a while to get the change oil light to go away.
Bill
Old May 11, 2008 | 01:00 PM
Exactly
What's the trip button? haha
Old May 11, 2008 | 01:08 PM
S1LV3R's Avatar
button located on the dash that cycles between trip and odometer and also resets your trip. Turn the key on (don't start car) and hold the button down until the "change oil" light blinks.
Old May 12, 2008 | 12:05 AM
FrankSS's Avatar
or u can turn the key on and push the go pedal 5 times to the floor real fast and it will clear it
Old May 12, 2008 | 12:26 AM
99mongooSS's Avatar
x1 Thats what I do turn the ignition on, but dont start the car. Then mash the pedal down 5 times real fast and then start the car.
Old May 12, 2008 | 12:59 AM
Relapse's Avatar
Don't however, start the car.. and then mash the pedal down 5 times
Old May 12, 2008 | 01:03 AM
SD99TA214's Avatar
i turned my key to the on position, pushed the gas pedal to the floor 3 times, watched the cange oil light blink then disappear. but any of these^^^^^^^ will work.
Old May 12, 2008 | 11:47 AM
andrew69_04's Avatar
your car's probably pissed at you for running penzoil in it......its trying to tell you something
Old May 12, 2008 | 09:20 PM
What's wrong with pennzoil 10w 30? WHat oil do you recommend?
