L92 Heads On 3.908 Bore?
suppose to have a 4" bore to run these, but ls1 blockscan go 3.908...that leaves .092".
what bout going with a smaller intake valve since they are huge?
possible?
one response:
"2.02 + 1.6 = 3.62
+ .060" or so for the area between valves = 3.68"
3.91 - 3.68 = .23
/ 2 = .115"
so , centered in the bore, there will be .115" (almost 1/8") from the edge of any valve to the cylinder wall "
basically I want l92 on ls1....
possible?
one response:
"2.02 + 1.6 = 3.62
3.91 - 3.68 = .23
/ 2 = .115"
also notice the valves are the wrong size in the response i posted in the original post:
Valve dimensions:
Intake = 2.160”
Exhaust = 1.590”
so the math changes....and i doubt the space between is right.
Basically the difference can only be .01" which can be fixed with a 1.55" ex valve. right?
Valve dimensions:
Intake = 2.160”
Exhaust = 1.590”
Valve dimensions:
Intake = 2.160”
Exhaust = 1.590”
Valve dimensions:
Intake = 2.160”
Exhaust = 1.590”
Why are you wanting to run this set up anyway?? just curious....
a "weak" ex port on these is super strong compared to almost every other ls1 head.
the cost to install valve seats is nothing to me. since i have them and the valves already.
basically these are so cheap($375 heads $200 intake) compared to afr 225's and others....and perform the same.
I'm wanting to build a budget 5.3 with these heads and see what it does....going in a s10.
I get the 5.3 for 300 and have a torque plate to bore them to 3.908 and with these heads it would be a super cheap build. just kinda dreaming at this point wondering if i should buy these heads. and see what happens, if its possible.
but if I cant get any better performance under 7k i wouldnt do it.
it would just make sense to get a 6.0 block tho, huh?
