a few cams
. it's an M6, i've got a K&N fipk, long tubes and true duals. this is a daily driver. i've narrowed it down to the 228r, tr230, and the tr230/236. i'm really leaning towards the last two choices. i'm going cam only for a while, but heads will come in the next year and i've heard the tr230 is best suited for cam only cars. how do these two thunder racing cams compare to each other with drivability, performance, reaction to heads, sound, etc? thanks in advance.and no matter what cam i get, i'm getting the ls2 timing chain, ls6 ported oil pump, and dual valve springs.
The cool thing about the Torquer 3 is it has engine dyno tested within approx. 7hp of the MS4 camshaft with earlier power production & better street manors.
http://www.texas-speed.com/shop/item...d=669&catid=44
Did I mention they're on special
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Parts:
Basic Camshaft Swap Gasket Package(Thunder Racing)
LS1 Cam Swap Package w/ Dual Valve Springs(Thunder Racing)
LS6 Ported Oil Pump(Texas Speed)
LS2 Timing Chain(Texas Speed)
Valve Spring Compressor Tool(Thunder Racing)
Harmonic Balancer Pulley Puller Tool(where do i get this?)
is this everything? i need to know all the parts/tools to get this done at my house.
thanks.
youll love the TR230 or X1.. bad *** street cams that i have never seen any regrets on.
