400+ RWHP... will this do it???
Old May 18, 2008 | 04:59 PM
chvycmaroz28's Avatar
im saying 415whpish
Old May 18, 2008 | 08:56 PM
'02 WS6's Avatar
Originally Posted by SOMbitch
I think your bud has something else going on. I am putting down quite a bit more with less cam and there are guys on here doing my #'s with stock heads Yes it's rare but your dude is way off with his #'s IMHO. Search Chris1313 on here and in the dyno section. He will make your friend feel really bad!!
He and I both know he has something going on. A 4000 stall w/ 4.10 gears that collectively eat a TON of power and spiral flow muffler which also has a reputation of being a power eater. None the less, peruse the dyno section and take into account the number of small cam only a4's that dyno 350-360, there everywhere. But the majority of them all run well in the 1/4, so in theory, who cares what a small cammed A4 does on the dyno when it's pulling an 12.0 and lower 1/4??
Old May 18, 2008 | 09:08 PM
squale iii's Avatar
Originally Posted by cdoggy81
I hope I can hook... The tires will be street tires, nothing special, but will be wide at 295/35/18
18 inch rims definitely won't help with traction...Low profile tires I take it?? Ya, but 295 is pretty wide.
Old May 18, 2008 | 09:25 PM
cdoggy81's Avatar
You are correct, LP tires on an 18" rim.
I'm not really building a drag car or anything (I'm more into the Pro-Touring style). For bragging rights I just want to be able to have my car run sub 12's & make 400+ HP at the wheels while looking good & getting 20 mpg on trips
One thing I forgot was I will probably need to upgrade my stock injectors. What do you guys think?
Old May 25, 2008 | 10:16 PM
cdoggy81's Avatar
Injectors???? What # if so; 32, 38, 42???
Also what about getting a Walbro 255 lph fuel pump? Needed or not?
