TR236 cam arrived today!
For those that were wondering what the specs were, My cam card reads 236.8/230.2 - 599/574 on a 112.0 LSA. I need to finish up some fine tuning with the TR230 cam (Which I just put in a month ago) and get a fresh dyno, then install the TR236 cam and see what happen's, should be interesting!
Dan
Dan
I have a few issues right now to sort out as well, mainly the 3.9 KR problem at WOT, pretty sure it's false KR but I need to get rid of it to get some good comparisons. This cam should work well with my ABS heads flowing 306 @ 600 lift. My best ET so far is in my sig, but that was with the KR problem and bad track prep (Hence the 1.80 60') on a 96* day and 2400' DA, so I doubt I get a good track comparison between the two cams, but should get a good dyno comparison between the two.
It's not up on there site yet, but I'm sure once the testing is done, it will be a good seller...
Dan
Dan
what are you doin with the 230 cam?, is it still in good shape?,
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Dan
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
I thought that cam was meant for mostly stock headed cars? are there any numbers suporting this cam yet or are you testing it out for them dan?
Dan
I hope you havent milled your heads ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Do you have valve reliefs in your pistons?
Cheers,
Chris
Cheers,
Chris
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Dan
Cheers,
Chris
Cheers,
Chris
Dan
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
Get that biatch in there foo... my 231/237 is in and now I just have to finish the trans swap
