would this work cam help
Old May 20, 2008 | 09:45 PM
crazygn's Avatar
Default would this work cam help
stock 99 block and pistons, stock ported 241 heads, what would it take to get this to work. Do you think it would take to much cutting in the piston
Livernois custom grind (comp) cam. 251/251 .661/.661 112 LSA
valve timing: open close
INT: 15 BTDC 55ABDC
EXH: 59BBDC 11ATDC
Old May 21, 2008 | 08:28 AM
HEMIETR's Avatar
I wouldn't run that with those heads regardless.
Old May 21, 2008 | 09:08 PM
88ls1blazer's Avatar
Notching pistons, yes.
Other things that would be required:
stroker shortblock, and WAY better heads...
