Should I replace spark plugs?
Old May 29, 2008 | 12:42 PM
WstTexas's Avatar
Default Should I replace spark plugs?
I am doing my LT & Y-Pipe install next week and trying to get everything that I need.
I am not sure if I need to change spark plugs or not, since I will already have everything else out. The spark plugs in there right now are the OEM plugs with 16K miles on them.
Should I go ahead and order a set of NGK TR55's or stay with the stock plugs for now?
Any other suggestions?
Old May 29, 2008 | 12:44 PM
TopFlite's Avatar
You might as well while you are doing the headers. It certainly will not hurt. TR55's are good plugs as i'm currently running them.
Old May 29, 2008 | 12:51 PM
zman1969's Avatar
Default plugs
at 16k? I wouldnt bother unless you break some of them. now if you had 50-60k on them I would . my .02c
Old May 30, 2008 | 09:46 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
I'd spend the extra $16 and put a new set of plugs in it
Old May 30, 2008 | 10:14 AM
Apollo0526's Avatar
Well, once the headers are on, when you do change the plugs, its not bad at all
Old May 30, 2008 | 11:07 AM
Jon@Texas-Speed's Avatar
You can go either way. Being that you already have them out putting the headers on, I would put in a fresh set of TR-55s. But if you want, you can definitely run the OEM plugs if you would like.
Jon
Texas Speed & Perf.
Old May 30, 2008 | 12:55 PM
Reloy's Avatar
plugs should still be good, but since you already have it apart...whatever your wallet can handle
Old May 30, 2008 | 02:16 PM
WstTexas's Avatar
Jon
Texas Speed & Perf.
PM Sent
Old May 30, 2008 | 03:29 PM
black00ssFL's Avatar
Well he may only have 16K miles....but his car is a '99. So built/bought in '98.....his plugs are 10 years old . Since you're changing to headers....might as well for $16. I know time doesn't really affect plugs, but still after 10 years I'd do it for peace of mind.
n/m I think I misread. Looks like he has had OEM plugs for 16K miles....not the original plugs and only 16k miles
Old May 30, 2008 | 03:35 PM
deadmanTA's Avatar
It helps to pull the plugs out for clearance during the install so you might as well change them out.
Old May 30, 2008 | 03:36 PM
5301113's Avatar
Same here . It would be very easy and fast while you have all that room. Save yourself a headache and lot of time
Old May 30, 2008 | 09:39 PM
Bill Bowling's Avatar
I would go ahead and change them.
Bill
Old May 30, 2008 | 11:55 PM
unSStoppable's Avatar
gotta agree, not that big of a deal and one less think u will need to think about in the futre(for a while)
