Texas Speed 233/239 on 113 LSA
I noticed on T.S.P. you get a choice of 112 or 113 lobe seperation for this particular 233/239 cam. I of course would like the choppy idle of the 112 l.s. but i notice most people on here go for the 113 l.s. Any reasons why? i've searched this site and found tons of info on cams but i'm getting lost fast since most of you guys have head work done too. These heads are stock. Would this cam be way to much?
i eventually want to get the F.A.S.T intake and 92 throttle body setup. along with some "wet" spray on it. Would this cam be what i'm looking for? This car would not be a daily driver but driven hard on the streets and drag race it for fun at our local track 8 miles away from me
Any help is appreciated!!! and ksths2 im hoping i just win this comp im in so i can win that bottle!
Just swap out the pushrods and springs and get after it man. You'll be good to go.
You do have simple bolt ons done already correct? If not I would recommend those before a cam in a heart beat.
The powerband on the 112 will be slightly lower in the rpm range than the 113. Give the guys @ TSP a call and talk to them about which one they feel would be best for your application.
General rule of thumb usually is that the smaller the LSA (110/111) the later in the power band you will see power (4,000+). In contrast, the larger the LSA (114/115) you'll see you're power come on a little earlier. Usually though you'll have a nicer, flatter curve with a higher LSA cam which tends to make them more streetable but some of the very low LSA cams such as the MS3/MS4/Trex etc seem to peak higher.
And no, stock springs will not support up to .600 lift. Not even close. You'll definitely need new ones. Contact TSP they will set you up with everything you need. Contacting the vendor is ALWAYS a better idea than getting your information from some yahoo on an internet website... Me included...
It's a good cam that you're going to enjoy no matter the lsa.
http://www.texas-speed.com/shop/item...d=172&catid=48
