Realistic expectations?
Old Jun 1, 2008 | 08:35 AM
fuzzyjk's Avatar
Default Realistic expectations?
I am looking to get opinions on what I should expect RWHP assuming a 15% driveline loss (M6) from the following set up:
2001 LS1 20K miles out of a Vette, stock heads
226/232 604/609 113+2 Cam
Under drive pulley
BBK Shorty headers (must use Shorty because of application)
3’ straight pipe exhaust no mufflers
Typhoon 85mm intake manifold
Dual 4’ custom cold air intake (directly to outside air)
Dead nuts Dyno tune
This engine is going in a 2250 lbs car. A rough guess would be great.
Old Jun 1, 2008 | 10:03 AM
SOMbitch's Avatar
2250 lb car. Daaayuuuum Sounds like fun : I'll guess 375.
Old Jun 1, 2008 | 05:26 PM
fuzzyjk's Avatar
375 rwhp?
Old Jun 1, 2008 | 06:30 PM
sreve's Avatar
rwhp should not be a concern if it will hook it's a rocket ship
Old Jun 1, 2008 | 07:27 PM
fuzzyjk's Avatar
Here is the car that the engine is going in. It is rear engine so traction should not be an issue. What about the RWHP opinions I have only 1 so far (thanx SOB).
File Type: bmp
Old Jun 1, 2008 | 07:36 PM
quick346's Avatar
with that light of a car i would def go more cam. like a 236xfi/242xer combo
as is with a stick should be low 400's rwhp my buddies ws6 made 390 with a mti 220/220 cam ls6 intake with mid length headers
Old Jun 2, 2008 | 08:01 AM
teke184's Avatar
the headers may hurt you a little. and you could definatly go better for the intake manifold (FAST..or stick with an LS6).
but with that much lift, and the duration...you should make 385rwhp. could easily increase that with better setup
Old Jun 2, 2008 | 08:17 AM
Jpr5690's Avatar
what kind of car is that?
Old Jun 2, 2008 | 08:20 AM
SOMbitch's Avatar
Beautiful Baby
Old Jun 2, 2008 | 02:06 PM
fuzzyjk's Avatar
It is a GTM. An American designed, engineered and built Supercar. Uses GM parts the way the Saleen S7 uses Ford parts. A stock LS6 (405hp) will send this car 0-60 in 3.2 sec and an 11 flat quarter. The LS7 (505hp) will do 2.98 sec. Think about what a TT set up (750hp) would do.
Old Jun 2, 2008 | 02:14 PM
99mongooSS's Avatar
Im going to say right around 400-410.
Old Jun 2, 2008 | 06:49 PM
fuzzyjk's Avatar
375-410 rwhp would be great. But that is a big range. I would like 400rwhp what could I do to improve the chances of reaching 400. Please continue with the opinions of the original set-up maybe I won't have to do anything.
Old Jun 2, 2008 | 06:58 PM
SOMbitch's Avatar
I only said 375 because of exhuast. I think you were smart to get split a cam since you are limited there by the shortys. Ported heads would put you there (400) no question. I could be wrong and you may be closer than I think though. All cars respond a little differently and there are the "Freaks" out there.
Old Jun 2, 2008 | 07:34 PM
Shawn MacAnanny's Avatar
How much was that, and where'd ya get it? lol
Old Jun 2, 2008 | 09:19 PM
fuzzyjk's Avatar
Bought the basic kit (body, frame and interior) from Factory Five. Purchased all drive and suspension from F-parts and it is being built by Midwest Classics in Ohio. I will be around 95K done. Faster than an Enzo for 1/12th the price.
Here is a weight to power scale to chew on: (all are crank HP)
Model/Weight/HP/Lbs per HP
2009 ZR1 3352 638 5.25
2007 ZO6 3222 505 6.38
Viper SRT 3437 510 6.80
2008 Viper 3460 600 5.76
GTM LS1 2296 350 6.56
GTM LS2/6 2350 405 5.80
My GTM 2296 460 4.99** Assuming 400 RWHP**
GTM LS7 2396 505 4.74
Ford GT 3468 550 6.31
Ferrari 599 3482 620 5.61
F430 3208 483 6.60
Enzo 3009 660 4.55
Gallardo 3153 520 6.06
Murcielago 3637 580 6.27
Murcielago 640 3670 640 5.73
SL65 4272 604 7.07
R8 3434 420 8.17
Cararra GT 3043 605 5.02
911 Turbo 3495 480 7.28
09 GT-R 3836 510 7.52
Bugatti 4162 1001 4.15
Lotus Sport Cup 1800 252 7.14
3 lbs power to weight club
S7 2950 750 3.93
Koenigsegg 2601 806 3.22
GTM TT 2406 750 3.20
Old Jun 2, 2008 | 09:34 PM
Hey um i hate you? Haha Awesome car man seriously. That's damn impressive.
Old Jun 3, 2008 | 06:28 PM
fuzzyjk's Avatar
to the top
Old Jun 3, 2008 | 08:13 PM
MrElectric03's Avatar
Thats a sweet looking car..how much was the kit?
I am using the same cam only the lifts are swapped, mine ins .609intake and .604 exhaust. I would guess about 370 to 375 rwhp with a good tune. I am using some 5.3l heads from tsp, im looking for 420 rwhp from my WS6 and 440ish with a FAST intake, maybe optimistic but it will fly either way.
Do you have to use short headers or could you maybe have someone in the area build some custom longtubes and that thing would scream.
Old Jun 3, 2008 | 08:24 PM
Jpr5690's Avatar
Dam Mabye Ill Go That Route...
Old Jun 4, 2008 | 10:17 AM
burnstacp's Avatar
I have close to the same cam with ported polished stock heads, pulley, headers. I am putting down 390. I also have an LS6 intake. I would say you'll probably be 370-375. If you want 400 look at getting some heads or a ported fast instead of the typhoon if you can afford it.
