Threw a rod bearing, what are my options?
He can get re-built for less than the cost of a new shortblock, there is no doubt.
The point I think people are trying to make is that if the money is say $ 500 away from a better engine why not go with the better engine. Like I had arecent guy go witha 383 over a 408 and the money was less than 400 difference. It didnt make sense to me but maybe he didnt have the 350 more it took to get the 408 so he did as best as he could for his money. No one will or should disprespect that. Its an economics decision.
If you dont have a good budget then you need to do what ever you have to. Buy used parts if need be and get it going again. There is more than one side to the coin but it wont be on the same playing field as a short block prepped by a professional. Maybe thats all you need though.
A shop put this motor together not even a backyard mechanic..
https://ls1tech.com/forums/generation-iii-internal-engine/924763-super-technical-help-needed.html
I guess this person didnt read that how to be an expert book that you read.
If you think all it takes is a set of tools and a manual then go ahead and open your own shop and help the rest of us out
Just throwing that in there.
If you had plans to buy heads etc, then it changes the game, but there is more to that selection than a $400 shortblock price tag
I propose that you find out what's wrong first, then start thinking about options. It may be a sub $1,000 fix and you just won't know until you get in there. No reason to throw money into more than it takes to fix it unless you just wanted an excuse to upgrade
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Many people go with a 383 or 370 over a 402/408 because they already have AFRs or trickflows etc that will work GREAT on a 383. It's not more cost effective to spend another $400 on a shortblock when it costs you $2400 heads
Yes and what you do is your turn around and sell your Trick Flows or AFR's that hold good value and ugrade your heads just in the same way your upgrading your short block.
LOL. Your not strapped with the same heads by any means and the best way to build bigger and better is to sell your old stuff to help offset costs.
This is done all the time, its nothing new. All you need do is look in the for sale section and you find a premium sets of heads that someone is selling to upgrade to bigger heads, short blocks being sold to move to bigger ones.
You could buy a set of used bigger heads as well and save money at the same time your selling your old stuff. If the block isnt trashed its worth a couple three hundred in a quick sale ... BOOM .. money to offset costs...
Lots of ways to upgrade without breaking the bank, 400 more for the 408 short block: get $350 for you current block and all of sudden the 408 is only $50 more. Same thing with heads. If you dont have a set to sell then look for used LS6 stage 3's . They're cheap on here all the time. Throw them on there until yo can save for some premium heads and your good to go...
If all you have is 2500 then obviously your not looking at a shortblock but a re-build or a take out from someone buying a new shortblock. Lots of options in that price range as well. ITs a 408 not a 427 or 440, you dont need $4000 heads on it if its built correctly, to make power.
I've always sold my used stuff on here very quick when I priced it to sell. My long 347 with AFR"s I sold for $7400, and my left over ls1 for $350 cash with a bad ringland on one piston.
Where theres a will theres a way...LOL but maybe not if you just dont have the budget. You do what you need to do first and what you want to do second.. if you can afford it..LOL
Or, you get the 370 or 383 for $400 less, sell your old block for that $350 you speak of, and now you're at $750 under the price of a 408 and it become even more sensible to keep your current top end and build a 383! Damn I'm good at this. Then, instead of selling an awesome set of heads, you bolt your old setup onto your new shortblock and you're making killer torque with an entire assembled engine for hundreds less than ONLY a 408 shortblock. No selling heads, finding used heads, upgrading to a fast90 right away if you were running an LS6, no extra wiring adaptors (more$$$ for the 408 that wasn't already accounted for ), smaller injectors that cost next to nothing off of a terminator cobra.
The 408 doesn't always make more sense. Different strokes for different folks. Maybe my PUN skills need some work . In a situation where it IS just as cheap or easy to go 408, of course it is the better choice, but in many other situations, a 383 WILL save you money and hassle and perform to the customers exact needs and desires.
__________________
Another option is getting a used shortblock of the LSX for sale section like 99blancoss said. That would be another cheap route. If it was me though, I would just get it working with the idea of what if it happens again, and be ready to start saving for a new forged block or fresh stock shortblock. All of us are performance entuisiasts and want more power, but that would be the real world logic though unfortunately not being prepared to spend $3000+. A shortblock may be $2700,, but need to think about the little things it will need to be installed (gaskets, fluids, etc..)
Lots of options...just depends on your price range.If you have the cash I would agree with 99blancoSS and go for a 402 or 408, then of course you would have to go all the way with some trick flows or afrs to match it.
A 383 would be ok but I think the motor would do much better with some better flowing heads, the TSPs are awesome for stock cubes but I dont think they would let a 383 work to its full potential, and if your going for a 383 why not just go 402 or 408.
It shouldnt cost much to just reapair the spun bearing, if thats the case.Mostly time in machine work.
Lets see you get it done for that. $700 to fix an engine that has a spun bearing. Why would anyone pay to have an engine built in the first place really, if all they can do is buy some parts and bolt them together themselves.
Because after you've wasted 3 or 4 grand and had it not work or blow up again you have to spend even more money to do what you should have done in the first place. Have it built by someone who knows what they're doing.
These aren't legos they dont just snap together. I had a shop teacher tell me once he could rebuild and engine with some vise grips and a screw driver but he wouldnt want it.
OP:> If you feel like you can rebuild your shortblock, give it a shot. No real harm in trying. Are you gambling??? Yes, but look at the risk reward.
3 options:
1) Rebuild yourself for $700 and it works=> Great, you save $3300 on shortblock
2) Rebuild it yourself and it breaks => Your out $700, and have to buy the shortblock anyway but maybe you learned a thing or two
3) Buy the shortblock => Sweet, you have a forged & stroked motor.
Anyway you look at it, life ain't that bad. Good luck on your build. If you do decide to go with a new shortblock, 99blancoSS sells a quality product he will build to your needs.
I just came into the same exact issue. Last Monday I took the car out to do some tuning and came home with a knocking engine.
5 days later I had the motor out in my garage with all the internals torn down and knew what I had on my plate and what parts were damaged. My knock was fairly quiet, and after taking it apart, my crank is basically garbage so my options were to machine it for $250 and run 10 over bearings, or I could have ran a pull out factory crank from a local LSx shop for $275. But I also found two other rods that looked like the rod bearings weren't far from spinning (graphite colored oil behind them and all sorts of marring on the rods...
So after considering all this I started looking at stock and forged rotating assemblies. I found prices from $1400 to $2500 plus... then I starting thinking that I didn't have that kind of money to repair this so I started searching through for sale ads...
I found a local sale for a short short block, built on the LS6 block and a stock crank. Mahle forged pistons, JRE forged rods, full ARP bolts, a set of milled/ported/polished 241 heads, hardened pushrods, and a number of other items including injectors, gaskets, etc etc... for $1k.
Granted I worked a killer deal and was in the right place at the right time... but you can do the same! No way you'll come away from a spun bearing for less than $1000-1500 even if you're doing the work yourself. Because its a must to turn the crank as well as have your entire rotating assembly inspected for issues. If you don't, you're basically wasting your time and money because you'll be back in the same spun-bearing-boat quickly as the issues you over looked blow all the effort and expense you've invested when they too fail...
Good luck and just make sure you take your time and do it right!
-Eagle
-Eagle
#32
LMAO! I didnt think it was a contest. I like to go bigger and better. But I can certainly see your point. Not everyone has the budget to do what I would do. When I was 18 I certainly didnt have the funds I do now for a new shortblock and I had to buy used everything.
My 370 or 383 or 347 wouldnt be that much cheaper than my 408 thats why I dont offer one So I gues it's all relative.
I would never settle for a 370 or 383 when I could have a 408 for a little more. When I bought my 347 the difference was much greater and so I settled for a 347. But Now the difference isn't that much and so I see it differently, but then again my shortblock probably cost a little more anyway.
You need to set your budget to begin with, that's the first step. I'm sure we can agree on that.. LOL or maybe not feel free to debate that if you want to.
It isn't impossible to fix it yourself either as suggested and I wasn't kidding when I said you could find used parts to save money. So I'm sorry if I appeared to say that there is only one way to do it being my way..LOL wasnt my intention.
I guess my point is, don't always upsell when something cheaper is exactly what a customer wants and will make them more than happy. People get PISSED when the price difference grows to well over $1000 when they are told the difference is going to be $350-$400. It's just a matter of opinion and informing the buyer, I plead the fifth from here on out.
__________________
#33
Well maybe when you sell something it ends up costing more and you've experienced upset customers due to it. Its not the case with my customers, they know what they're looking at when they talk to me.
I offered my point of view and my shortblock and explained how I see it. You seem to want to think your way is the only way to look at it. I've stated, I dont know how many times, there are options as to what he can do, this is what I would do. You can explain your point of view but I think it should have ended there, but for some reason your persisting. I dont care to discuss this anymore with you so I'll drop from the thread.
I direct my customers to aother shops all the time who dont have the budget for my 408 . LMAO! I dont tell them this is your only choice and you have to use it..LOL
This is not an upsell...LOL an upsell would be telling them they need Oliver rods when the Callies Compstar are fine because I make more money from the Oliver... thats an upsell.
Overing my smallest cubic inch engine is not. Its my least expensive option.
__________________
#34
A friend of mine spun a bearing, he put a new piston, rod, polished the crank, and put it back together.
If you do the work yourself, you can do a strong bottom end with your stock block for less than 2k easy.
It all depends on if you are doing the work and your plans for the car.
#35
And Scoggin-Dickey wins it!
Makes perfect sense, I would love to build a 454ci blown beast but my budget says I have to choose between a small stroker with cheap heads or a 346 with a stock crank and budget forged rods and pistons with trick flows.
I spun a bearing years ago on my 1980 Z-28 350. Basic machine work, 2 used stock rods, and a used stock crank later she was back up. I had Dart Sportsman 2 heads and decent sized cam and she hit 6400rpm many, many times and never did blow up again. ran damn fine on a budget.
You can build a good shortblock without having to tell the kids they don't get to eat anymore.
I like Trick Flows.
I like Trick Flows.
#36
I respectfully disagree CodeRedSS on here is making 470+rwhp N/A and 640+ on spray with a 383 with PRC 5.3's and MS4 High 10's N/A and he won't tell us what he is running on the spray yet
#37
Ok I guess I got stuck in sales mode, sorry.
As for the 383 Tony Mamo put down over 550 rwhp with his setup so there is power to be made with the engine no doubt! The power comes from the heads and cam selection. There is a vid of him running a 10 I think in it floating around here somewhere. It was very impressive!
#38
Really? Thats interesting...I stand corrected. I have yet to see numbers for those heads on a 383, though they are great heads for a great price...I cant wait to put them on my motor!
#40
I just got off the phone with him and the 10.9's were on his old tune. He's now 10.5's N/A Maybe he'll chime in. I think you will like that setup just make sure you get your compression up by flycutting or running dished pistons to keep up your DCR. He is at 11.6 SCR.
