Cam Question.
Old Jun 10, 2008 | 04:04 PM
TheBiz's Avatar
Default Cam Question.
Heres a quick scenario, a true scenario, but a scenario none the less. What should I do, or will I even have a problem..
Stock LS2 shortblock (20K on the clock)
Patriot Stage II LS6 heads, milled .025 (2.02/1.57)
Custom Grind Cam 236/248 .601/.615 on a 110+2
I'm almost positive I will have PTV issues with the milled head and that cam. My question to the motor gurus, should I cut the pistons, or sell the heads and just buy an un-milled set from Gunnar? Will I have issues with an un-milled head as well, or will I be good?
Thanks!
BIZ
Old Jun 10, 2008 | 05:50 PM
98RedZone's Avatar
Your already going to have the heads off, so milling isn't as big of a deal. Some of the older Patriots had the chambers welded and re-milled, so they didn't need to be milled on the bottom. If you could swap yours for them, that would be easier.
Old Jun 10, 2008 | 06:15 PM
JPH's Avatar
JPH
Flycutting will be in order for sure.
Old Jun 10, 2008 | 06:55 PM
TheBiz's Avatar
For which head setup? Milled, un-milled, or both?
Old Jun 10, 2008 | 07:47 PM
98RedZone's Avatar
The TRex fits with stock heads, and its 242/248 110. So its possible your cam will fit. Either way you need to check it. Might be better off just flycutting.
Old Jun 10, 2008 | 09:48 PM
TheBiz's Avatar
I had planned on spraying. I'm not all that cracked up about weakening the already weak stock pistons. Is there a write up anywhere for fly-cutting? For some reason my search is acting all funny.
Old Jun 11, 2008 | 10:28 AM
JPH's Avatar
JPH
Milled. I would check the non-milled too?
Old Jun 11, 2008 | 10:34 AM
Fratsit's Avatar
Here ya go.....
https://ls1tech.com/forums/generation-iii-internal-engine/709183-how-flycut-pistons.html
R/
Frat
