? on milling heads
Old Jun 10, 2008 | 07:40 PM
jonnyc's Avatar
Default ? on milling heads
how much would you have to mill a set of 241 heads to get them to 60cc?
thanks
Old Jun 10, 2008 | 08:20 PM
Viper's Avatar
1cc = .006 so what do the 241's start at?
Old Jun 10, 2008 | 08:23 PM
IMD's Avatar
IMD
66cc
so .036 to be exact.
Old Jun 11, 2008 | 08:31 PM
GuitsBoy's Avatar
66.67cc chambers technically. I milled .040 and consider it a 60cc chamber.
Old Jun 11, 2008 | 08:34 PM
PONTIAC SLP's Avatar
gains ? how much RWHP u get from milled heads
Old Jun 11, 2008 | 08:59 PM
Michael02hawk's Avatar
Doesn't milling the heads favor added torque, with minimal hp gain?
Old Jun 11, 2008 | 09:03 PM
GuitsBoy's Avatar
I milled the heads at the same time I ported them out, and swapped to an ever so slightly larger cam, so its tough to say. Its true that the primary result of higher compression is torque, but for any given RPM if you increase the torque, you increase the HP too. The main advantage to milling is the added drivability. it really gives you back the low end you tend to lose when going cam only. Do it. Youll be happy you did.
Old Jun 11, 2008 | 10:22 PM
jonnyc's Avatar
i can't remember the exact formula,but i think for every 1 point you increase compression you gain 10% power.so if you were 10.25:1 and had 400hp at 11.25:1 you should have 440 hp.
Old Jun 12, 2008 | 06:15 AM
woow amazing so good luck , don't forget to share graph dyno
Old Jun 12, 2008 | 06:40 AM
GuitsBoy's Avatar
I dont know about all that. It might be a good theory, but in reality the numbers just arent there. A 400 HP cam only car needs to get some seriously good flowing heads as well as a bump in compression in order to hit 440. My guess is that a going from 10:1 to 11:1 is only gonna bring the car from 400 to 410 RWHP. But thats just a number pulled right out of my ***.
Old Jun 12, 2008 | 08:34 AM
LS1C5Vette's Avatar
This sounds more realistic, maybe a TAD higher for a full point in upping the compression.
Old Jun 12, 2008 | 08:55 AM
SOMbitch's Avatar
Sounds about right to me. I have always read 2% per compression point.
