408 vs. 346 flow needs
Old Jun 13, 2008 | 07:17 AM
CBIII's Avatar
Default 408 vs. 346 flow needs
So im having a disagreement with a buddy *famous last words*
my lq4 had GTP Stage 2 heads and a tsp 231/237 cam, fast 78mm intake.
The arguement is that he feels that I will LOSE power with these same parts (minus the intake, im going to a ported 92) on a 408 versus a stock cubed ls1 or my iron 6.0.. anyone?
Old Jun 13, 2008 | 07:37 AM
RZRSEDGE's Avatar
I'm no expert; but I don't see you losing power. Probably not optimal; but not going to lose power.
Old Jun 13, 2008 | 09:06 AM
CBIII's Avatar
thats my stance. It will still make more due to increased displacement and will make alot more after I upgrade these at a later date.
Old Jun 13, 2008 | 11:16 AM
1bdbrd's Avatar
OK I'll bite. I'm the buddy.
My stance was that they are still pulling in the same amount of air because the heads will only flow so much. Since they are pulling in the same amount of air, the smaller engine would be able to use it more efficiently and effectively. Much like a turbo. On an ls1 a smaller turbo might make a certain amount of power but that same turbo on like a honda might make more power at the wheels. All because the smaller engine uses the incoming air more effectively.
Old Jun 13, 2008 | 11:36 AM
jmm98LS1's Avatar
Not quite. The 408 is absolutely going to make more power than the 346....adding displacement always = more torque. My explanation may not be 100% accurate number wise, but the theory is what matters. Here's how I see it: Say the cylinder head flows 300cfm----the 346 is going to ingest 43.25 cubic inches of air into each cylinder during the intake stroke whereas the 408 will ingest 51 cubic inches. They are not pulling in the same AMOUNT of air (bigger cylinder = more volume), they're just ingesting the air at the same RATE of 300cfm.....(cfm = cubic feet per minute).
Old Jun 13, 2008 | 11:42 AM
CBIII's Avatar
and at what point would the heads (ls1 casting) be overwhelmed?
Old Jun 13, 2008 | 11:54 AM
jmm98LS1's Avatar
I did a little looking in the Advance Tech section to see what people WAY smarter think and found this:
Torque is more directly related to displacement. This is because it's a more a factor of cylinder fill rather than cylinder fill * speed. The same cam heads intake (assuming that this is the limiting factor, not strength of parts or knock or float) will usually produce the same (similar) max power within a wide (but limited, i.e. don't use a 1 c.i. engine compared to 400 c.i.) range of displacements. The torque (at lower RPM than peak power) will always be greater with more displacement. The intake system has more of a %efficiency factor for obtaining torque, but a max flow limit for obtaining power at high speeds.
Harmonics and component mass and friction will fight this theory a little, but it's more of a generality.
In general with the same heads, cam, intake:
Big engine will have greater torque, obtain peak hp sooner, and keep a flatter peak hp curve. Also will have more area under the curve.
Small engine will have lower torque peak, and peak hp late and peak in a sharp manner, but can achieve about the same peak power.
Makes sense.....
Old Jun 13, 2008 | 12:06 PM
1bdbrd's Avatar
Ya know, that does make sense now. I always looked at CFM as a flow amount, NOT flow speed.
Old Jun 13, 2008 | 12:16 PM
jmm98LS1's Avatar
If I'm understanding everything I'm reading, it seems we were both kind of on the right track though. More displacement with the same top end will produce similar (probably a little more) peak HP as the smaller motor, but the peak occurs at a much lower rpm and produces more torque throughout the power band. Check out some of the threads in the advanced tech section, there's some good interesting reading on this subject there......
Old Jun 13, 2008 | 12:54 PM
CBIII's Avatar
so were in agreement that it will make more power (sooner and longer) than a smaller counterpart, but is not necessarily ideal.
Old Jun 13, 2008 | 01:04 PM
Stang's Bane's Avatar
Your basic idea is sound, but once you started expanding on it you got messed up..
The air is not getting pulled. It is flowing from a higher pressure to a lower pressure. May seem like it doesn't matter, but it does.
Old Jun 13, 2008 | 03:30 PM
99blancoSS's Avatar
Yep, the only thing that will happens is the 408 wont have the top end it would with proper heads, but all along the rpm cycle should be improved in hp and tq until it hits the choking rpm point where it wants more air but cant have it
Old Jun 13, 2008 | 04:04 PM
CBIII's Avatar
Old Jun 14, 2008 | 01:07 AM
sixt9er's Avatar
Many people get torque and horsepower mixed up...THE BIGGER ENGINE WILL ALWAYS MAKE MORE TORQUE, considering all is the same except for displacement. HP will be close though, as was explained earlier in the thread.
Old Jun 14, 2008 | 01:13 AM
99blancoSS's Avatar
One thing to note here... heads and pistons.. if your running a 59cc head and have a 408 built for the proper compression (correct dish piston) for that head and then switch heads to say a L92 that has like a 75 cc chamber.. your compresion isnt going to be what you want.. you cant shave that head to 59cc's althought I guess you can have it welded. You need to plan it out. One thing effects another with an engine build and if you start doing things without a plan you end up spending more money that need be.
Old Jun 16, 2008 | 05:39 PM
CBIII's Avatar
I think ive got this step taken care of. TFS heads arent too big that they cant be easily milled to match the chamber size of the ls1 castings that im using now.
Old Jun 16, 2008 | 06:25 PM
99blancoSS's Avatar
^^ Sounds good, I just like to point it out to people that different heads have different valve placements and it makes a difference with the piston. So they dont have any suprises later..LOL
Old Jun 17, 2008 | 03:16 PM
Brian Tooley Racing's Avatar
The valves on a 13.5 degree TFS head fall into a standard 15 degree LS piston, because the valve was rotated at the head.
But you are correct in what you are saying on a ET 11 degree or LS7, because they are totally different.
BTW, a turbo or blower have limited displacement, and a naturally aspirated engine has an unlimited supply of 14.7 PSI of air. This is why turbo and blower cars suffer more from making the same power no matter what the engine displacement they are on.
If your 6.0L heads are a little oversized (230+cc and big valves, 2.055-2.08) on a 5.7, then they can make quite a bit more power when coupled with the bigger 408 bore (which the 6.0L heads work better on) and a Fast intake. Conversly if you have a 210cc-220cc LS1 head with 2.00-2.02 intake valves and small exhaust valves and keep the LS intake, then you could very well make exactly the same peak power, just like was stated above.
