Forged 347 Oil Pressure
Old Aug 12, 2008 | 08:31 PM
AFASTYZFR1's Avatar
EPP installed oil pump and cam along with the rest of the shortblock.....
I installed pick-up, and pan and had to remove entire motor to fix everything before initial start up
also why does one bearing look more destroyed then the rest of them......if it was starved of oil I would think all would be destroyed
Old Aug 12, 2008 | 08:42 PM
EPP's Avatar
EPP
Originally Posted by Frost
The motor was never started without the o-ring. It was turned over with the starter motor without injectors or coils hooked up to prime it. It would not prime (no o-ring). The o ring was installed and the clearance between the pickup and pan was checked. The engine was primed again and then started. The owner was very meticulous with everything, as can be seen when looking at how NICE and clean he has done all of his work.
What else was hurt besides the main bearings?
Cool, I thought maybe it was fired up with the o ring missing. I'm just trying to figure out what happened, it indeed looks strange. Main bearings are not a problem in these engines, and they look fried.
We'll have to replace the crank or get it turned, we'll probably replace it. We'll install a new oil pump and new lifters, as we don't want to take a chance as debris could be in them. Everything else looks good, pistons are okay, cylinder walls are good, etc. Bob
Old Aug 12, 2008 | 08:49 PM
Frost's Avatar
Man I am glad to hear that nothing else was chewed up. Bob, if you guys have any questions at all that you'd like to ask me about anything, gimme a ring at work tomorrow at 804-767-1168.
Old Aug 12, 2008 | 08:56 PM
EPP's Avatar
EPP
Thumbs up
Sounds good, thanks. Bob
Old Sep 7, 2008 | 10:27 PM
AFASTYZFR1's Avatar
Exotic Performance is an A++++++ shop.......customer service is excellent.....motor is fixed and will be on the dyno asap......do not hesitate to do business with them
Old Sep 8, 2008 | 11:49 AM
Frost's Avatar
Excellent customer service like this is why I continually send my own customers to them for ATI parts, rears, rotating assemblies and more on a regular basis.
