Forged 347 Oil Pressure
I have the plugs out, no spark, and no fuel and I cranked it for around 5 seconds twice and pressure only comes up slightly.....do you need to hold it for a long time for pressure to build?
And if someone from epp can let me know if the "bar bell" looking part was installed on the motor when it was there I would appreciate it (have read the it is located on rear of motor and has to do with oil pressure)
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Thats good info about the plunger..
http://www.exoticperformanceplus.com...php?service=92 Bob
when we started to do wot tuning on car oil pressure dropped to 20psi so I shut car off and trailered to EPP
afr was fat at 10.8 with only 15 deg timing and only made 2 wot passes until pressure dropped
What else was hurt besides the main bearings?
