Comp 918's...
Old Jun 17, 2008 | 12:08 PM
JJ 86's Avatar
Default Comp 918's...
Can I run these springs with the G5X2 cam? The specs are 232/240.... .595/608 114.
Old Jun 17, 2008 | 12:31 PM
The Alchemist's Avatar
UNDER PRESSURE MOD
I'd personally reccomend the PAC springs. PAC were the original suppliers to comp when the 918s came out, and when they left to soure them elsewhere is when comp had the problems with the 918s.
PAC makes a nitrided version of the beehive spring for our cars that is good for .650 lift.
Here's info:
http://www.pacracing.com/Street_Stri...Set_of_16.html
And here's some pricing..
https://ls1tech.com/forums/showthrea...ht=pac+springs
Old Jun 17, 2008 | 05:35 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
The new 918s are rated to .625 lift. They'll work fine.
Old Jun 17, 2008 | 06:34 PM
BlackScreaminMachine's Avatar
Internet Mechanic
I have then in my VRx4 cam 228/230 @ 112 w/ lift below .600" they are the revised version.
Old Jun 17, 2008 | 10:39 PM
twin74s's Avatar
i have them on my texas speed 233/239 .595 .603 cam Been to 6800 many times already without a problem so far.
Old Jun 18, 2008 | 11:53 AM
JJ 86's Avatar
These I believe are the older design. They have the blue stripe and are black. The pics of the newer design that I've seen have a silver look to them. These came with a new cam package that I bought here on the fourm. Not sure if these will work with the cam though (the previous owner bought them to use with the cam when he purchased the cam pkg).
Old Jun 19, 2008 | 12:24 AM
twin74s's Avatar
I have heard bad things about the older design with the stripe on them. Who knows the new ones could just be repainted ones. Like i said my combo has only about 500 miles on it but it has been to 6800 many times already.
BTW are you from springfield mo area, maybe on 417racing?
Old Jun 19, 2008 | 02:36 AM
Lilscottie's Avatar
Why not use the PAC Springs? Lots of good things going around about them
Old Jun 19, 2008 | 06:43 AM
UNDER PRESSURE MOD
Either of the two pac springs are better. Why run the risk of using a spring that might break which would then cost you a lot more than $200-$250 for new springs.
Old Jun 19, 2008 | 04:51 PM
Mr. Luos's Avatar
Personally...after all the issues with the 918's, I won't be putting a Comp valvespring on my car.
I went overkill when I went with a smaller cam and threw on dual valvesprings.
Now, been beating on my Patriot springs with a 629/622 lift cam.
Probably go with Manley duals when these get to 15K miles.
Old Jun 19, 2008 | 06:32 PM
OWN3D BY MY PROF!
There's nothing wrong with comp springs. It was only those batches of 918s that went out. I'll be using a set of revised 918s in my new engine and a set of 26089s once I get some money saved up.
Old Jun 19, 2008 | 06:46 PM
allthrotle's Avatar
Be careful with the manley's I believe you have to change up your valve seals I would stick with the patriots if your having good luck with them. Im running both the patriots and the 918's on both my cars and no problems with either.
Old Jun 19, 2008 | 07:54 PM
Mr. Luos's Avatar
Good info.
I hadn't really researched them yet, as it will be a few more years before getting to 15K on the current ones.
Old Jun 19, 2008 | 08:18 PM
tilly's Avatar
I have a quick question about 918s?
Sorry for the Hijack.
Can you use stock retainers and locks with the NEW 918s?
Old Jun 19, 2008 | 08:45 PM
HSV-GTS-300's Avatar
Revised 918's
http://www.ls1gto.com/forums/showpos...&postcount=105
Old Jun 19, 2008 | 09:21 PM
Mr. Luos's Avatar
That isn't normal??
Did COMP help out?
Old Jun 19, 2008 | 09:22 PM
twin74s's Avatar
Yes you can. I did in mine.
Old Jun 19, 2008 | 09:29 PM
Internet Mechanic
The springs that break can break for a couple of reasons...
1) install error
2) improper breakin
3) spec'ed for the wrong cam
4) not allowing the springs to heat up before whacking it with high RPMS
I've seen Pat. Duals break, any spring can break.
Old Jun 19, 2008 | 09:40 PM
1) install error
2) improper breakin
Yes, it's the ones which break for NO REASON you have to worry about.
Old Jun 19, 2008 | 10:17 PM
sappy96's Avatar
I have some slightly used 928's for sale
https://ls1tech.com/forums/showthrea...790&highlight=
