Porting LS6 Intake
Old Jun 26, 2008 | 06:25 AM
PassionateZ's Avatar
90mm is awfully big guys....why go that big?? i wouldnt go past 80 maybe 85mm...I mean, unless he goes H/C soon after the intake installation, it would be a waste IMO..
Old Jun 26, 2008 | 08:23 AM
firechicken76's Avatar
[QUOTE=sschkade;9628245]My source is a book... "Dyno-Proven GM LS1 Thru LS7 Performance Parts," not to mention the countless "online" sources like the one posted above ^^^ (thanks 95 Z28). ...and the fact that it's been discussed here on LS1Tech on several occasions (search)!
I have that book, yes the ls6 is better than the ls2 intake! its not about size its about flow!
Old Jun 26, 2008 | 05:24 PM
GuitsBoy's Avatar
You can match up the runners but you cant get too far up inside them. It will help, but I cant see it being worth more than a couple HP, but if you do it incorrectly, you could negatively affect performance and be down a couple HP. That being said, I did mine, and I didnt feel like I lost anything down low, which is the primary concern.
Old Oct 10, 2008 | 11:57 PM
zachness's Avatar
The LS6 flows better because its a single piece design and the LS2 manifold is a 3. pressurized gasses can find their way through almost anything. Just what i've read on it.
Old Oct 11, 2008 | 01:30 AM
00pooterSS's Avatar
Here is my question, you plan on running a 224 cam, do you really think you are going to need 90mm tb? I think a ported stock 75mm TB and a LS6 intake would be plenty sufficient for a 224 cam.
I dont personally think the TB will be a restriction with stock heads and a 224 duration cam, are you gonna retain stock heads? If not then a better intake setup would be worth it.
